The most stupid car audio rumors
Lawlz in most home cabniets sq guys will use 15" speakers or bigger. They are not the same as the car audio speakers we use for lowend output. Any sized speakers can be build for any frequncy bandwith within reason. So to say 18" speakers sound like crap on music is a little idiodic to say.
I can say I worked for a high end loudspeaker manufacturer. Car 18" drivers dont cut the mustard! Hands down. Super crazy mms of over 400 grams pushed by a 3" motor doesnt equal sq. It equals mud. Saying my comment is idiotic is a bit far flung. One 18" driver that has car potential/ also very good home potential is the aurasound nrt18 bad ass sub! Your right with in reason about any size driver an be built for a given bandwith. unfortunatley an 18" driver that play under 20hz up to 100hz -/+3 db is not the norm.. As by boy john bender might say "Not even close Bud"
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
a guy was playin his system at my job and me bein the basshead i am i went to check it out. here are the 2 more i got from him
Im not runnin my true setup cause i dont have the watts to :trippy: ok how does that even make sense. who buys a system and realize their amp is a couple hundred watts off from pushin the subs to their limit and they go out and buy a second set of subs till they can afford a bigger amp
ME: it sounds pretty ok
HIM: OK?! my amp is only 1/4 way up. :orly3::noob:
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
"under powering" a sub will damage it.
As a noob it's nice to know that it won't. I've always seen people say that it does. I didn't get how that was possible.
Sorry I did not word it right, there is this idiot I know who says it's impossible.
When in realty it is possible by sending the woofer a clipped channel.
not exactly. i read somewhere that a sub that can handle...either 3 or 4 times the power of the amp (cant remember which for sure) then you can clip that amp to all hell and the sub will not get damaged. forget where i read that tho.
and not sure if it has been said yet, but a dvc sub hits harder than a svc sub. lol
Here is one.
"You cant make a box for 6) 18" subs out of plexiglass."
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
My sub is better cause it moves back and forth cause it is dual coil. Your sub only moves out cause it is single coil. Lawlz.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
I cant figure out if people in here are
pro= you can blow a woofer by under powering it.
con= you cant blow a woofer under powering it.
Here is my take you can blow a 1000 watt sub with a 100 watt fairly quickly if the amplifiers is sending out any reasonable amount of dc voltage. A sub might be able to handle 1k of clean ac all day but fail quickly when getting 15 volts of dc.
the rumor was underpowerin a sub would blow it, since most people, noobs, dont know the difference between dirty, clean, clippin, and not clippin generalizes it. but no sub is blowable by underpowering with clean power unclipped. true story
