XS Power
I see that Powermaster Batteries are the official battery of SMD, But what about the SPL Alternators...I know Iraggi is used mostly, but what about these Adjustable voltage Alt's...Or are they real expensive and the common folk can't afford them?? I've never seen anyone with one of these.
http://www.powermastermotorsports.com/spl_alternators.html
I see I didn't read this far down..
The SPL alternators are specifically designed for trailer only extreme competition vehicles. Because of the radical design, output at idle is usually 0 and because of additional heat created; these units should not be operated at full output for more than a few minutes. In some cases, SPL units can be custom installed as a second alternator to the original unit for street applications. However, caution must be taken that only short-term loads are sent to the SPL alternator.
Edited by zaxfire69
I doubt it...I was checkin out the battery's and run up on these..I bet they are expensive...Wish they would bolt onto our little Honda engines..Ha..
I dont know if Im reading this right, they have something the iraggi doesnt do.
With additional components XS VOLT units can be setup to charge a vehicle’s 12-volt system in primary mode and then, when needed, step voltage up and switch the charge over to a 16-volt battery bank in a secondary mode for competition.
So if that means that you can charge your front battery and run your car off 12volts while having your stereo and rear batteries getting 16 volts Id be willing to drop some money on that.
As I read on:
That kinda makes me not want it. I know the iraggi will work for daily driving where as the powermasters wont.
Edited by audiofanaticz
Just need to make it work as a second alt... Somehow...
Obviously some kinda custom bracket maybee a tensioner to make it happen..
If I can only get it inplace of the AC compressor, I'd drop the 500 bucks (well I'd look around) for it...
Looks top notch and after using a few powermaster products, it probally is...
I bet those suckers are horsepower ROBBERS
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Yeah, never mind the 400lbs of stereo in the back
i was all wet when i first read about them a few years ago... but if you think about it its the same as any other big externally regulated alt. nothing new
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
oh btw someone calculated the power my ohio gen externally regulated large gm case alt robs the engine of and it is a whopping 6hp... im not concerned
