Question for DC Rob or DC Kyle?
I installed my DC 260sp alt along with my stock alt the other day, and checked voltages.
Prior to install, stock alternator only- 14.1 at battery car idling with no stereo, no A/C
13.8-13.9 at voltmeter in cab of truck with no stereo, no A/C
After install, stock alt and DC Power alt- 14.1 at battery car idling with no stereo, no A/C
13.7-13.9 at voltmeter in cab of truck with no stereo, no A/C
I checked the voltage coming out of each alternator, and the stock one is charging at 14.20 volts, the DC Power is charging at 14.07 volts.
I am not bashing DC, I am just making sure that everything is kosher. The harness was pretty simple with the instructions from Kyle, the plug, a wire for ground, and a wire for switched power.
I just wanted some help from you all, as most of you guys who have used DC alts, always talk about having voltages up to almost 15+, I kind of expected this as well. It does help some with a load on, but kind of expected to see a bigger difference. Maybe the relay could be bad or something?
Have you upgraded your big three yet?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
For 15+ you have to run a VCM or MLA.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
Guest DC Power Kyle
Our XP series GM regulators are set at 15.1 out of the box. SP GM regulators are set at 14.7~ Only way the voltage is that low is due to one of those. Keep me updated and if you have any problems feel free to call us at 888-441-0144.
that's bullshit... ^^^^
my dc 270xp runs 15.6 volts and i have NO mla module or any other after market add on crap
:orly3:
That's great, but this guy doesn't have an XP and runs his w/ a stock alt.
Edited by UnderLoK
Pioneer X8500
2 270a Mechman Alts
Could be the battery, or his voltage regulator keeping him from charging that. Idk i will let the experts do there judgment here :D
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Or the engine could just be really hot... The higher the temperature of the regulator, the lower the voltage set point will go. Almost all regulators have a thermistor built in to them to lower charging voltage as temp increases to prevent overheating.
  • Who's Online   1 Member, 0 Anonymous, 1164 Guests (See full list)
