Why is the Audioque Clipping?
you want them wired in parallel, not series series is giving you 4 ohm at the amp, parallel will give you 1 ohm (i think you said their d4s?)
its not the amp.
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
And my JL w1 wit a 360 watt amp was hitting harder
have you taken any of the steps any of us have said yet? your quick to jump to conclusions
Team Sundown Audio
im bout to walk out side and start messing with it. Do you think there could be a problem with the subd
might be a blown coil along the way. pop test them, wire a 9volt battery to the terminals, if the sub goes in or out on that termina that coil is fine, do it to all pairs of terminals
Team Sundown Audio
subs should be fine, just make sure that the amp is wired correctly down to 1 ohm you may have it to 8 ohms if it sounds quiet or higher, if you wired it to .5 ohms then it would be louder. Your amp is fine just set everything right and its all good take a picture of your gain setup and post it on here ill check it in the morning (gain all the way up usually is bad) lol
i went to today seriesed the wires at the amp.
iirc you cant really do that, its a mono amp so im assuming there is 4 connectors 2+ and 2- , they are all for the same channel. its like like having 1+ and 1- except they give you an extra of each to make it easier to wire more than 1 sub for instance.
So i hope your not combining pos and neg leads from ur speakers and then putting that to the amp... that dont sound good to me
you have to series the woofers before the amp not at the amp, because its all one channel. it parralels the two + and - together
maybe i misread but thats what it sounds like to me
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
http://www.the12volt.com/caraudio/woofer_configurations.asp
use that
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results
to get to that
and here is a picture for how you should have your subs wired in the box
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
just make sure all positives are wired together, and then all the negatives are wired together lol it wont get any easier than that
Team Sundown Audio
That's how I read it too, lol.
we really need an epic face palm smily for some posts in here, but on a serious note, if your clipping its most likly your settings on the amp, and if your clipping that bad, your subs/sub could possibly be blown ( thats a guess )
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   0 Members, 0 Anonymous, 583 Guests (See full list)
