santo Posted October 15, 2010 Report Posted October 15, 2010 Ok so i have a question. I am building a set up on a Dodge Durango and I thought about placing the amplifier in the small compartment in the rear (like a small trunk in the very rear). The compartment has a lid and it completely shuts and will be lack of ventilation. Know my question is will it get too hot in there enough for the amp to go into protection? This will not be competition but it may have a usual loud play times. I thought about creating some chambers and and using fans to evacuate some air and inject some air in there.... not sure if it will be worth the work. Any help will be welcomed.
BeatBox Posted October 15, 2010 Report Posted October 15, 2010 IMO do fans for sure one to suck the air in and one to take the hot air out. it will be worth the work, better than maybe having to replace the amp itself
baaudio Posted October 15, 2010 Report Posted October 15, 2010 i agree with beatbox. better safe then sorry. id put a fan on each end blowing across the amp. that cools it better then directly on it. Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
santo Posted October 15, 2010 Author Report Posted October 15, 2010 i agree with beatbox. better safe then sorry. id put a fan on each end blowing across the amp. that cools it better then directly on it. Yes I thought about it the problem is that i forgot to mention that there is the windshield liquid reservoir so.... i have to move it because the owner does not want me to take it out!! i guess is better safe than sorry..... i will follow your suggestions.. thanks
P4killer_ Posted October 15, 2010 Report Posted October 15, 2010 Yes just use one of one 4 or 5 pin 12v relays, hook up ur fans like they said above, and youll be golden if the "cabinet" you putting it in is carpetted id prolly try and mount the amp on a piece of mdf instead of directly on the floor, well shoot no matter what kinda floor it is id mount it. but carpet kinda insulates heat, so whenever possible i like to avoid putting anything electronic in carpet mounting situations ie:. ppl put thier x360's and Ps3 on thier living room carpet, and lough and behold eventually it starts over heating.. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
AA98hoe Posted October 15, 2010 Report Posted October 15, 2010 put it under the seat or in the side compartments in back TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Mtnbikecrazy55 Posted October 15, 2010 Report Posted October 15, 2010 yeah, under the seat is a sure winner!! I hate long signatures.... ...what the fuck is wrong wiht you you fucking fuckity fuck fuck head... Mtnbikecrazy55 Feedback
santo Posted October 16, 2010 Author Report Posted October 16, 2010 put it under the seat or in the side compartments in back Actually since its a 15.. the box kinda takes most space in the back. the only space i actually have is underneath the box (2 inches) or inside that compartment like i mentioned. the owner thinks inside would be safer and there is where i plan to put it.
big dee Posted October 16, 2010 Report Posted October 16, 2010 i would try to put it under the box if theres room and put some fans on it like these guys are saying. and it should be fine. but dont let it touch the box or it could vibrate the amp and cause probs. what amp are you useing? you might want to tune the amp later down the road so keep that in mind when you mount it . in the compartment might make it tough to get to. look at steves build . the way he did his amps under the box works nicely imo. and if you can get it udner the box you wont have to move the washer resevor. moveing that might be a job
