how many aeroports and what size
The general rule is a joke.
Only meant for people who can do the proper formulas to figure the port area.
Exactly.
You don't use box volume when you are figuring out minimum port area. You use the Xmax and SD of the driver.
Read this page: The Subwoofer DIY Page, Port Calculations
Minimum Port Diameter
To calculate the minimum diameter of the port required to prevent port noises, you will also need to know the following:
Xmax = maximum linear displacement (mm)
Dia = Effective diameter of driver (cm)
Np = number of ports
Calculate the minimum port diameter from the following equations:
Sd = pi*(Dia/100)^2/4
Vd = Sd*Xmax/1000
Dmin = 100*(20.3*(Vd^2/Fb)^0.25)/Np^.5
where,
Dmin = minimum port diameter (cm)
Note: You CAN use ports that have a smaller diameter than that given by the equation above, especially if the ports are flared at both ends. However, at higher volumes, you may notice some port noise caused by the air rushing through the ports.
That general rule of so much port for such as size of box has absolutely no bearing on whether the OP will have port noise or not, which was his original question. The enclosure is not moving the air in and out of the port, the DRIVER is. /rant.
97 Maxima SE
Bunch of shit going in, check out the build
Exactly.
THANK YOU!!!!
Bobonit, I disregarded the port noise question, my bad. But I do have some experience with aero's and that is where my arguement comes from, that aero's usually (not always), need less port area.
SMD Super Seller
My Feedback Thread
Oh, I'm sorry if it looked like I was singling you out, I was not. I was mainly responding to all the posts of "Oh, for that many cubes you need this big of a port" not you personally.
Yea, any flared ports require less than the usual port area in regards to noise. Now, if you are talking about how much port area to get loud, as in regards to SPL, I'm out on that one :)
97 Maxima SE
Just me, but in a 6 cube box I would slot port it, aeros do best in small enclosures.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
I have one 6" aero on 2 cubes. If it wasn't a case of length being a issue I would have used a 8" for my 12" sub in 2 cubes. I have 14^2 of port per cube with this aero and would rather have 20-25^2. I had two 3" aeros on the previous box which was only 1.5^3 net and had a shit load of port noise because of not enough. Listen to bobonit. If you come up needed a minimum port of 10" then that's what the sub actually needs. If you want to use slot instead do the same equation then make the slot close in port area to your answer. So if you need a 10" aero. 5X5Xpi= about 78.5" of area. So a slot port to match would need to be around 20t X 3.5w for about the same port area.
It's not about how much port per cube. It's about how much air your speaker will displace in it's excursion.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Also use the least amount of ports for the area you need. If a 8" is what you need it's better to use one 8 instead of two 6" or if you need a 6" the 6 is better then four 3" because there's less surface area the sound has to pass through.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
  • Who's Online   0 Members, 0 Anonymous, 1551 Guests (See full list)
