Each sub will see 500w each from the 1000w amp, so if you were to have 4 subs each would see 250w each. Your distributing the power across all the subs from a given amps available power.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I know a mono amp can drive two subs, in parallel, what i don't get is the power distribution, If i have two subs in parallel on a 1000 watt amp, is it 1000 to both subs? or is it 500/500 ?
If the subs are wired in such a way to give the amp it's rated load, then the rated power it makes is divided among the subs.
Honestly, how do you expect an amp to start making more power based on how many subs hooked up to it? so yess, 1000/2 = 500 per sub
1000/3 = 333.3333333333333 per sub
if you look at the specs of that amp, it says number of channels, 1-mono
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
Alright, so any suggestions for 800W RMS monoblock amp? smaller and cheaper is better.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
Kicker zx750
(2) Kicker L5 12's
Alpine IDA-X305 HU
Dual Optimas
Big three
Kenwood EQ
RF Components
Hifonics Brutus 1K (Subs)
Alpine MRP 250 (Mids/Highs)
Lots o' sound deadening
im just saying, i had a coustic 4 ch on 2 pioneer competition whatevers, 2 channls per sub, sounded great considering chinese subs and horrible coils.
JUST BECAUSE YOU DONT KNOW WHAT SQ IS DOSENT MEAN OTHER PEOPLE DONT. KEEP THAT IN MIND.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Kicker zx750
It's a 4 ohm load though..
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
Thought you said you had 4ohm DVC subs? 4/1=1
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
First of all, "4/1=1"...No. 4/1 is 4. and i was going off this diagram: http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_mono.jpg
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
Wire them in parallel: 1 ohm.
Wire them in series-parallel: 4 ohm.
Wire them in series: 16 ohm.
Those are your options with two dual 4 ohm VC subs.
Kicker 750 will work at 2+ ohms. I've run mine down to 1 ohm but it blew the 3x25a fuses regularly (3x30a didnt blow). Wouldnt recommend it for daily...
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 511 Guests (See full list)
