i just finished doin my big 3 and want to make sure i did it correctly.
heres my negative battery terminal
there was a post sticking off my stock terminal so i connected the chassis and engine ground to this post
as for my positive terminal
i kno its hard to see but thats my alt. positive wire ontop of my amp power wire.
i left all the stock electrical hooked up, and fused the alt. wire
is it ok to do it like this or do i need to get new batt. terminals? with dual 0 guage outputs
its fine like that.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Fused your alt wire? That isn't really necessary, just make sure that the wire to the back where your amps are is fused. And tuck the alt wire somewhere safe where it won't touch anything hot and where it can't rub on anything moving.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
Should be okay.
@baaudio, epic avatar.
I'll second this, being a ravens fan
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
Should be okay.
Meh, I'ma Steel City fan (have to be, I was born there :peepwall: )
Either way, just thought the move was funny, Ben takes too much of a beating.
POTATO!
you did the right thing by fusing your run to the alt. better have it than not and it short and burn your whole car down.
2006 Nissan Z Track.
My Feedback Thread
how can this happen
i have a positive current coming from the left (battery) and say i fuse it 12" within the battery i still have a positive current coming from the right (alt) because i have my stock wiring in place as well as my alternator is STILL PUTTING OUT CURRENT so if anything does happen that fuse blows, both wires are still live
in order to prevent that you would need to fuse it on both the alt side and the battery side
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
i dont have anything fused for the big 3. i know i should, but what the heck, im too lazy to add a fuse.
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
not smart ^
My Feedback Thread
