so my dad gave me his old 98 centry buick.
what is required to make a wall for 2 18's?
pros and cons:
do i takeout the back seats?
is there in enough room cubic ft wise?
do i need to use the trunk space for the enclosure also?
and is there anyone in houston that wants to help build it with me LOL
system:
changes way to much...
Im sorry for being a dick
Edited by SmokedOut08Impala
2006 Nissan Z Track.
My Feedback Thread
i used to think a band pass was something you were around your neck or something.
you don't have the experience to do a wall yet, so i wouldn't.
Just because he doesnt have experience with a wall doesnt mean he shouldnt try it, thats how you gain experience.
The first time you have sex do you have any experience? NO, Doesnt mean u shouldnt try it.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
well he asked what he needs to do. Obviously the first step is to see what you have to work with, sq footage wise. If you don't know that, then you obviously don't have the experience to build one. I see this as a dream wall too. I don't see it happening. Just my .02
1 more asshole comment from you to this kid and im going to give you a much needed vacation for a few days..
Team MaxRetribution
Si Vis Pacem Parabellum
yeah the back seats have to go and you will not be able to see out the back so your goin to have to rely on your mirrors but walled sedans are cool good luck with this if you decide to go forward with it
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
pros and cons:
Yes, you would take out the back seats, and most would use 2x4's to build a frame for the MDF to attach to(I.E. the 2x4's are attached to the body/sheet metal)
If you are doing a full wall at the B-Pillar you should have 0 problems with Cu. ft. issues
No you wouldnt, for 2 18's, use it for batteries and amps....
Im sure someone on here in that area, should have exp. with walls, its definatly not the easiest of tasks, but it will help alot for you to do your first wall while being helped/taught by one of the experienced wall builders
Edit: Also depending on the Subs you use/amps you use you will likely need electrical upgrades for the amps, and suspension upgrades to handle the weight of the wall, subs, and extra batteries needed to feed the amps(still dependent on subs you choose)
I think I got everything, also expect hairtricks once the wall happens.
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
Shouldn´t be too dificult, that car is very confortable on the back seat area, that means when you take the seats out, you´ll have tons of space for a wall, 2 18´s or 4 15´s should fit in there without any problems, you have the space, but, do you have the subs?electrical? amps and everything or you just starting to plan this for the future?
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
