Agm batteries- Diehard platinums
i have a diehard platinum and was wondering if it ok if the battery charges at 15.0 volts when the alt cold and drop to 14.7 when it hot? I added one diode and my system charges at 14.0 when im stopped at a light and when im moving it charges at 14.3. So i might think when i start it up cold it might be charging at 15.3 15.4.. So please someone chime in and help thanks,
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
short periods shouldnt hurt it....
i.e. cold start voltage
constant high voltage charging will cause swelling
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
i have 3 of them a p-4 up front and 2 pm-1s in back and charge at 15.6 cold and 14.9 warm so you'll be fine and have been for over a year with out any issues so you should be fine
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
anyone else?
so if it exactly 15.0 volts will that be ok it will rise to the 15 when im driving and when im stopped and static at a light it will drop to 14.7 -14.9 volts?
im gonna be adding 2 of these to the alt. I have one diode installed already.
So you're doing this to help keep your voltage up at idle or low rpm?
Any pics of the mod?
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
