DC 5k for sale
DC 5k used for 2 days at show last weekend about 1 hour on it not 1 scratch on it taped mounting feet...bass knob and all orig packing. 950 shipped OBO
The 5.0kw competition series amplifier is a 5000 watt mono block. Its capable of running up to 18 volts for up to 7300 watts. It is a linkable amp and designed to run a 1 ohm per amp or 2 ohms when strapped. It comes with a bass knob and a clipping indicator. For power inputs it will accept dual 0 awg for power and dual 0 awg for ground.
Key Features
• 1 ohm stable
• Variable low pass filter
• Variable subsonic filter
• Variable bass boost
• Wired remote control
• Clipping indicator
• Dual 0 awg power and ground inputs (both must be used)
We recommend for installation
• 1 upgraded battery under the hood
• 1 extra 800ci battery in the rear
• Minimum of two 0 awg ran from the front battery to the rear battery
• Both 0 awg power and ground inputs on amp must have 0 awg ran to them for a total of 4 runs into the amp
• Upgraded aftermarket alternator
• Dash mounted voltage meter
Items Features Voltage 5.0kw
Output Power (RMS) at 4 ohm 14.4V 900W x 1
at 2 ohm 2300W x 1
at 1 ohm 5000W x 1
at 1 ohm 16V 6000W x 1
at 1 ohm 18V 7300W x 1
Input Sensitivity 6V~0.2V
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Bass Boost Variable dB 0-9dB
Frequency Response Hz 15-270
Signal to Noise Ratio dB 100
Damping factor 150<
Efficiency @ 4ohm % Over 90%
THD @ 4ohms Less than 0.1%
Fuse Rating 500 Amps
Linked Fuse Rating 1000 Amps
Indicator Power Yes
Protection Yes
Clip Yes
Speaker & Power terminal Mold Type Yes
Power Gauge 0Ga
Heatsink Length inch/mm 25.59"/650mm
Heatsink Width inch/mm 9.38"/66mm
Heatsink Height inch/mm 2.35"/59.6mm
is it 1k for each amp or for both? im sure you mean for each.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
ok i figured. gotta love stupid questions. i doubt you will have these in the future because everybody loves dc but im looking in the fall for a setup like that for a single smd 18. if you should have these near the end of the year keep me in mind otherwise glws. trink40.gif
