tin snips and a pair of balls
and big forearms
is an understatement
R.I.P!
(Nov-29-2009)
92 explorer
current build
^ and band aids.
wll kinda of an update i found out there are small dots on there and they look like welding spots from the car, a guy from work told me he wouldnt cut there because thats what gives structue to the car
true?
and if so does that mean im pretty much fucked lol
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
don't do it
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
okay thanks man, so pretty much what i can do now is build from inside the trunk then,
correct?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
ya, you can do that.
what i did was weld a 1.5"x 1/4" x the lenth i needed, metal bar. to the top of the rear deck just along where my cut ended. never had a problem at all. car is a 02 lincoln LS
2-18" Fi Btls
2-RF T2500-1bd
box 14cu.ft after displacement tuned @ 32hz.
Socal Box Designer/builder
well the thing is the resale value will it go down and im only 19 so my welding skills are very very basic because im barley getting trained in the mantainence at my job after im finished with my main job
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
those little "spot welds" are not holding your car together...
  • Who's Online   0 Members, 0 Anonymous, 464 Guests (See full list)
