DC Sound Lab
dc lvl 5 18 low end box?
Ok I have a 6.5 after diss box tuned to 35hz in the trunk. I am wanting to do a low end monster that will peak at 26-30 hz. What do i have to do to achieve this? im thinking 9cuft box tuned to 25hz. The big box because i am low powering the fuck out of it. 1500bdcp. Slot port or circle port or a wood port diamond shape that i will be able to take out to change tuning, this port changing would also be done using the circle port too. I dont know im thinking 4 4inch circle ports. give me some input people. Thanksss
I predict some severe clipping and popped woofers
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
he got a vid on his system on his sig idk i wanna say ford focus
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
If you wire 1 amp per coil instead of strapping make sure you invest in an oscope to properly match the gains and to make sure there is no clipping. Also consider that if you build a bigger box, you will get even more rise and therefore get less power out of your amp. With the box specs you have now I wouldnt worry about rebuilding and would jsut get a bigger amp. Possibly consider matching the sub with a DC 3.5k. Shoot me a PM if you are interested.
my 5 on roughly 2000rms likes 7 cubes with aero ports to hit the lows real well
4 6in aero ports tuned to 33 34 should do fine
Edited by kbsmoker
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
