DC Sound Lab
Could they take 3500 each?
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
Not going to recommend it but if you know what you are doing and can properly scope your entire system from HU to amps and make sure it is PERFECTLY CLEAN POWER, you will be pushing them to their absolute daily limit. Also a custom spider pack will be needed to help handle all of the extra power.
I'm sure I'll get corrected but clay from the A team has done a ton and I mean a TON of testing with the XLs and supposedly a stock XL can take 3K with the right box and user... Supposedly anything above 3K just generates heat..... An jeff is running close to 5k on each of his (2 1100.1s on 4 XLs) but he's got an upgraded spider pack (assortment of soft and mediums) that if Iirc was advised by clay...
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Are they 18s?
I saw a walled explorer walled with 4 XL 18s on a sundown 3500d on each sub
I think the guy is 91explorer on here and he said the subs handled it good
He has 9 XL twelves on 6 sundown 4500d now
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
There are alot of thing that have to be done right and done by someone that knows exactly what they are doing but it can be done. But remember that if you fry the coil, that is on you and not on the company that made the sub.
I was just going through all this with my rebuild asking the same questions... Till be around 3,500 per sub before rise but true clamped power will be more like 2,500 or so per sub....
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
the XL is louder than a lvl 5 up to 3kw, but the XL can handle 3.5kw...
OP if ur wanting to buy a 3.5k amp id go for the XL>5, after rise & voltage drop u will prolly see <3kw from the amp...
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
Just because someone has a 3500 on a sub, doesn't mean it's getting 3500. Box rise and voltage drop sucks ass.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
