RockFord4lyfe Posted May 13, 2011 Report Share Posted May 13, 2011 well that sucks... so how exactly does the PCM determine what voltage to output..? Link to comment Share on other sites More sharing options...
Purplehaze Posted May 13, 2011 Report Share Posted May 13, 2011 well that sucks... so how exactly does the PCM determine what voltage to output..? I'm guessing it is a preset number based on what the sense wire tells it. My question is this, if there is no way to manipulate these kind of systems, how does an MLA work? Does it basically bypass the PCM? Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build Link to comment Share on other sites More sharing options...
la negra Posted May 13, 2011 Report Share Posted May 13, 2011 pm sent to ami customs and 97ssblazer So, did you try it? If so, which one, brown or grey? I'm guessing if you did, you're not liking the results? i tired the brown wire but nothing happened so I took it off Now reading what could of happened im happy I did Link to comment Share on other sites More sharing options...
la negra Posted May 13, 2011 Report Share Posted May 13, 2011 For all others who attempt to try this, yes, putting a diode or resistor on your sense line will raise voltage, but don't do it unless you ABSOLUTELY know what your doing.. On EVERY GM made from '86 up, the S wire is the sense wire if so equipped, some vehicles however dont run an external sensing regulator and only have the LF terminals (which is different than the 2 pin RVC altogether).. Don't ever start putting resistors/diodes on any L or F or P terminals.. On the L wire, you can overload the lamp driver and smoke the regulator, on the F wire, your going to raise/drop the field monitor voltage to the PCM and your vehicle will not like you, and unless you really want to start blowing diodes up, by all means don't put a diode on the P terminal unless you want to directly short your diodes out. P=phase, it's a hard wired pinout to the stator, and has a constant ~7.36v DC output.. So what do u advice us to do if we have a Gm ad244 alt with only 2 wires brown and gray. Can we add a wire to the S terminal of the alt ? Link to comment Share on other sites More sharing options...
bdubii Posted May 17, 2011 Report Share Posted May 17, 2011 The diodes I ordered finally showed up and I installed them and gained 1.45 volts. My truck now charges at 15.45 volts when it's about 80 degrees with the radio, headlights, and ac off. Thanks to loudcivic for finding out which wire was the sense wire for me and also to the op. My build, four 15's walled: http://www.stevemeadedesigns.com/board/topic/106855-07-tacoma-walled-off-with-4-15s/page__p__1487297#entry1487297 Link to comment Share on other sites More sharing options...
BFF Larry Posted May 21, 2011 Report Share Posted May 21, 2011 can anyone help me on a 95 pontiac bonneville sse? Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931* Link to comment Share on other sites More sharing options...
knowledge Posted May 21, 2011 Report Share Posted May 21, 2011 x2 i need this bad voltage drop and all is crazy low. i have a 2003 honda crv with 12k and need help, if anyone can help me on it pm me thanks REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need. Link to comment Share on other sites More sharing options...
BFF Larry Posted May 22, 2011 Report Share Posted May 22, 2011 i just did it, i had to add a sense wire and i tapped into the 12v egr wire and added 2 3 amp diodes. im running at 15.6-8 around 1800 rpm Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931* Link to comment Share on other sites More sharing options...
SPL KID Posted May 23, 2011 Report Share Posted May 23, 2011 i just did it, i had to add a sense wire and i tapped into the 12v egr wire and added 2 3 amp diodes. im running at 15.6-8 around 1800 rpm How and where did you add the sense wire? NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything Link to comment Share on other sites More sharing options...
Sammitch0 Posted May 26, 2011 Report Share Posted May 26, 2011 How do I do this on my 96 Jeep Grand Cherokee Laredo I read 14.4v Cold and 13.2v Cold I want 14.4v Warm Grand Cherokee Team Backwoods Bumpers DC 15" Level 3's /w 4 Coils Pioneer deh4200ub Pioneer 3-ways Pioneer Tweeters Pioneer GM-D9500F Audiopipe 1500.1D @ 14.4v Clarion Equalizer Knuconeptz Kollosus 0ga Knuconpetz Kollosus 4ga Coming Soon: 270xp / xs1200 Link to comment Share on other sites More sharing options...
