using diodes to step up voltage
i made one with a resistor and a potentiometer for about $10. so i can adjust to what ever voltage i want :) 12v to 21v. i have a thread somewhere on here
werent you the guy that wouldnt tell anyone how to wire this up? if not im sorry for the confusion.
pretty sure i posted how i did it in the thread, maybe not?
DC.jpgDC POWER
ok yea i havent seen the tread in a good while. I just remember reading somthing similar to this, and the person wouldnt let anyone know how they did it.
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
All this mod does is trick the alt into putting out more voltage. If a MLA works than this should work, you just have to find the right wire.
I'll probably try it, just a little scared b/c Chrysler. But not too scared. Where there's a will there's a way, rt?
I'll let you know how it turns out!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
I think you would have to bypass the PCM, if it controls the voltage like steps it back to 12.5 like the newer GM's I know do. And you have to tap into the sense voltage on the regulator.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Yeah let me know so I can try it on my jeep. I talked to MLA and they said like $250 for an MLA mod and I said why don't I just do this and he laughed at me and said it was stupid and they would save a lot of money if it was that simple.
:shrug:
Well, after a little research, I have found that there is a little more to it than just diodes for us that drive MOPAR. Like AMI said, the voltage reg. is built in to our cars PCM, so that has to be bypassed.
I think for my Cruiser I'll just go w/ MLA, but for my S10, the diode trick will work just fine.
Thanks guys for sharing this info, I agree this should be a sticky!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
I was looking into buying a mechman GM Adjustable Voltage Boost Module but found this tread, I took a closer look at the harnest and sall a micro potentiometer. I was woundering if they use diods with a potentiometer or just the potentiometer? Anyway I went to Radio Shack and picked up some diods and a protentiometer and see what I could do.
yes that can work. wut pot did you get because the lower pot like a 10k will have a fast increase as you turn resulting in a spike at a certain point. if you use lets say a 50k you will be able to fine tune it better and not have such a big spike.
2015 silverado crew cab
nothing atm but soon...
i tried using different diodes and the results to my car was not what i thought it would be, it gave a lower voltage but kept it steady instead of fluncuating.
Results before adding diodes, 15.2 cold start, 13.0-14.2 warm
Results after adding diodes 13.6 cold start, 13.6 warm on 1 6 amp diode
13.4 cold start 13.4 warm on 2 6 amp diodes
13.2 cold/warm on 3 6 amp diodes
and what is the purpose of a potentiometer?
Are you SURE you got the correct wire? I am yet to see results like yours :shrug: A potentiometer would be adjustable.
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
