Okay... So I am going to be getting my first car (2001 Neaon) soon and I want a nice System that isn't to much money but still hits hard.. I am currently looking at these Kenwood KFC-W3013PS. I am planning on ordering 2 of them with this box Sound Ordnance™ Bass Bunker Sealed dual 12" subwoofer enclosure. Also this is the head unit I am planning on getting Kenwood KDC-348U.. I need help on deceiding on what amp to get preferably a Kenwood and I don't know what wire to use.. Also I let me know if I missed anything I need cause I thought you only need Subs, Box, amp, wiring.
Thanks,
Austin
Hey Austin, welcome to the site :D
I can tell you right now that Kenwood isn't known for their subwoofers, and buying prefab boxes is a no no. If you give us a budget to work with, we can find you something that will sound much better, and I'm sure someone here can give you a design to build your own box.
X2
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
Thanks for replying my budget is around 500-700 dollars. I not sure what's good or bad cause I was looking at reviews on the stuff and most of them were 4-5 stars so I thought is was decent stuff, but thanks for your help.
Austin
For 500-700 I'd say get an Audioque 1200D, a DC LVL4 either 12" or 15" then you'll still have money for a 4 gauge Knukonceptz wire kit and a sheet of 3/4 MDF to make a nice box.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Austin, I would suggest messaging Dwright27 about pricing for a DC Lv4. To run it, I would get a AQ1200 amplifier. I would use the KnuKonceptz 4gauge install kit. It will have everything you need except speaker wire, which you can also find on knukonceptz.com
You can find some 3/4" MDF at Lowes, and build your own custom ported box. I would suggest using Torres box calculator to figure out everything you should need to know about building the box.
If you have any questions, don't hesitate to ask :D
im assume he meant neon
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
I smell a Crutchfield Catalog :sigh:
2007 Pacifica
With that head unit, you can hold off on buying an amp for mids/highs since it's got a high pass filter built in. It won't get you far with only 22watts a channel (HUs are usually overrated anyway) but it's a start. What did you have in mind for mids and highs?
2007 Pacifica
