Jmoney2544 Posted April 26, 2011 Report Posted April 26, 2011 I've Heard some goog things about this wire but the only thing i see is that it's aluminum and not copper. how many amps can this knu 1/0 hold compared to stinger 1/0? Ill be using a aq2200d Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
blownengine Posted April 26, 2011 Report Posted April 26, 2011 Their KCA cable is CCA (Copper Clad Aluminum) The Kolossus Flex cable is pure copper. Thats the good stuff that you want. 1/0 knukonceptz will be plenty for that 2200. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
carlosg_313 Posted April 26, 2011 Report Posted April 26, 2011 Their KCA cable is CCA (Copper Clad Aluminum) The Kolossus Flex cable is pure copper. Thats the good stuff that you want. 1/0 knukonceptz will be plenty for that 2200. this. KCA worked fine for me and still does with my hifonics brutus 2010(2krms). if you thinking about doing the big 3, use pure copper wire for the quality. How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman
RickyFriery97 Posted April 26, 2011 Report Posted April 26, 2011 Their KCA cable is CCA (Copper Clad Aluminum) The Kolossus Flex cable is pure copper. Thats the good stuff that you want. 1/0 knukonceptz will be plenty for that 2200. ^ this And is capable of loads over 300a I'm doing my big three in all Kolossus flexs 1/0 and running a AQ2200D 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
ZombieswithMustaches Posted April 26, 2011 Report Posted April 26, 2011 I used the KCA wire and I've had great luck with it! I wired my Big3 and all my amps with it! It's sounds really good! I noticed an increase in volume right after I installed it!! Float mounted IPad Mini playing through Bluetooth IStreamer for Iphone or Ipad Rockford Fosgate 3Sixty.3 RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors Two Rockford T600-4's for the components Blowthrough with two Sundown SA-8's RF T1500-bd's for the subs 8000k H.I.D.'s in headlights and fogs Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift) 17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's Undercover Bedcover Surco Roof Rack Five Hella Lights on front bumper 270A Mechman Alternator Two Optima Yellow Top batteries Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
D-train-13k Posted April 26, 2011 Report Posted April 26, 2011 i actually had this question today. for a guy like me who has a tight budget how much of a difference will the kca and the kollosus cable make. i plan on running an aq2200 as well. The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
blownengine Posted April 26, 2011 Report Posted April 26, 2011 i actually had this question today. for a guy like me who has a tight budget how much of a difference will the kca and the kollosus cable make. i plan on running an aq2200 as well. They made the KCA cable a little thicker to try and componsate for the fact that CCA is less conductive. Even with that said their KCA cable is still better than alot of 1/0 cables out there. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
byers319 Posted April 26, 2011 Report Posted April 26, 2011 Their KCA cable is CCA (Copper Clad Aluminum) The Kolossus Flex cable is pure copper. Thats the good stuff that you want. 1/0 knukonceptz will be plenty for that 2200. its not pure copper.. its tinned
D-train-13k Posted April 26, 2011 Report Posted April 26, 2011 i actually had this question today. for a guy like me who has a tight budget how much of a difference will the kca and the kollosus cable make. i plan on running an aq2200 as well. They made the KCA cable a little thicker to try and componsate for the fact that CCA is less conductive. Even with that said their KCA cable is still better than alot of 1/0 cables out there. yeah at double the price i figured i would have enough wire of the KCA to do two runs to my back battery and maybe do the big 3 in 100% copper. that should be sufficient right? The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
zayres29 Posted April 26, 2011 Report Posted April 26, 2011 I used the KCA wire and I've had great luck with it! I wired my Big3 and all my amps with it! It's sounds really good! I noticed an increase in volume right after I installed it!! ummmm NOT Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
