Turning the gain all the way up does not mean turning the amp all the way up to 2,000 watts. And I'm going to guess there's some clipping now.
Yes I know that was the point i was trying to make to my friend. i dont know if there is cliping there is no audible distortion but i think by friday i should be gtting o scoped. Thanks for the input tho.
And supercharged DDs i cant wait to get it playin full tilt man this thing will still laugh at that power.
2000 Grand Marquis
Digital Designs 9512
Rockford T2000bd1
What kind of headunit do you have?
Yeah, that power is more suited for a 3500 sub like mine, you should strap two of those 2000bds and lower the gain a bit, then it will be full ;)
Gain should be matched to head unit signal voltage.
Not speaker impedance.
If the signal into the amp is 4v, you set the gain at or around 4v. Doesnt matter if its 1 ohm 2 ohm 4 ohm or any ohm on the output side. Gain is an input adjustment.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Pioneer DEh3300
Im pretty sure ill run and check.
Ha yea thats plan soon hopefully haha
Gain should be matched to head unit signal voltage.Not speaker impedance.If the signal into the amp is 4v, you set the gain at or around 4v. Doesnt matter if its 1 ohm 2 ohm 4 ohm or any ohm on the output side. Gain is an input adjustment.
Ok that makes sense thank you. So if i had a higher quality HU say like 6v i could tunr the gain up more with still with a clean signal
2000 Grand Marquis
Rockford T2000bd1
^^no, the gain would be lower with a 6v input than a 4v input.
Edit: it could be "higher." It depends on how you define "gain" and look at it.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
A gain knob is not a volume knob. Ever.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Say you're feeding an amp that makes 30v wide open with a 1v signal. The signal has to be 'multiplied' (which is actually what gain is measured in) 30 times.
If you have 100mV of induced noise then when you multiply that 30 times you'll get 3v of noise on your output.
If you feed the same amp with a 6v signal and adjust the gain accordingly then it only has to multiply the input 5 times to reach full output.
Edited by TeamHT
