I have a 9512 D2 hooked up to a RF T2000bd. I currently have it running at 4 ohms. I have my gained turned a little more than half way up to prevent clipping. My friend and I got into a discussion about how i should be able to turn my gain up full safely since im only running it a 4 ohms. My thoughts were even at a low power I would still create a clipped signal which would damage my equipment.
My question is since im running my amp at such little power and great efficiency would i be able to turn my gain up all the way and be safe at the low levels of power?
2000 Grand Marquis
Digital Designs 9512
Rockford T2000bd1
No.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
no just because your wired at a higher impedance doesn't mean you can just crank the gain. You could be getting a clipped signal at 1 ohm or 4 ohms just with the gain at half or any other level.
Use an O-scope to see at what point you are clipping.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
Ok thanks thats what i was thinking just making sure i was correct.
2000 Grand Marquis
Rockford T2000bd1
Quick question, why are you running it at 4ohms? Is your electrical not enough to handle the RF2000 at 1ohm?
I only have the big 3 done in 0 gauge and when i run it at 1 ohm it plays but i get bad voltage drop. so until get somemore upgrades im gonna stay at 4ohms.
2000 Grand Marquis
Rockford T2000bd1
Ah, I figured. Well good luck getting more power mate, that 9512 is hungry! ;)
Turning the gain all the way up does not mean turning the amp all the way up to 2,000 watts. And I'm going to guess there's some clipping now.
