No..on the dr trigger...
Read again...what makes the circuit funky?
How and when it opperates..
And your muffstain does the same thing
are you referring to the circuit that slams the entire electrical system shut after a certain period and you have to wake it up to make any kind of alarm work?
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
What is the material used in a transistor that lets it do its job..
Hint... Cali city
What are the 2 ways for a transistor to "layered"?
there's a cali city named germanium? lol (yes, some diodes use germanium as a substrate)
Principal
How can you use a dmm to check for a tach signal?
What should the signal be?
Does it vary? And when/why?
Set your DMM to AC current and find the odd colored wire on an injector or find the tach wire. I can not remember what it should be at this point though. It will vary as the RPM's increase though. I havent done that in a long time.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
This is good there are so many funky things in cars these days. Sleeping door locks, anything chrysler puts out lol
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
nice job jay..
but..
pin 2 for databus, purple wire
pin 1 if its LAN, green wire (11 bit and 29 bit)
of course it's 8mm..
I should have made i clear I was talking about bi polar trans. not just a diode..(good catch)
and 04-08 ferds dont fall asleep anymore.
they rest at (-) and go to open .... fun..haha
and n8, its ac volts. on 2 pin injector or C.O.P this is almost always the "odd" color wire. Not the common found on every injector.
What tool is needed to test the voltage drop in a circuit?
How is the test performed?
What kind of voltage drop do you mean?
The kind of voltage drop thru the wires and equipment itself or voltage drop like in :" using the circuit and then voltage drops because it's pulling amperage?"
But a DMM is the answer to the first one.
using a dmm you check for voltage drop across the load
or in more technical terms in parallel with the load
oops forgot a piece. the dmm should be set to ohms. so itll get a reading of the input voltage vs output voltage and cause an ohm load. smaller is usually better. the actual voltage loss can be calculated
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
you can do resistance then calc for how much voltage was lost...
or. you can do it the easy way.................................
  • Who's Online   0 Members, 0 Anonymous, 1959 Guests (See full list)
