Well considering the prices i think im going to go with the G36 in a 45 because its the new Slim Frame and its a sub compact which makes it tiny
Team MaxRetribution
Si Vis Pacem Parabellum
im doing just the opposite looking for a full frame gun or a pocket gun.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Depending on weather or not you're dead-set on one of those two, you might want to look into the H&K HK45Compact. I have owned the Glock 22, the Springfield XD45 and the XDm40, and Various Springfield 1911s chambered in .45, But my HK45Compact is my favorite for concealed carry just because it has an ACTUAL safety. Not just the dovetail/trigger safety the Glock and XD/XDm have. Also when you go to clean it, it comes apart just as easily as the glock or the XD, but you can remove the whole trigger assembly as a unit to clean/oil it.
If you don't like those, I would go with the Glock for CC. It's time tested and proven by law enforcement everywhere.
Hope this helps.
Ive been looking at Kahr as well....Everyone i have talked to says taht they are a step below a glock but very reliable/dependable weapons
Team MaxRetribution
I will never carry a gun that has any type of Thumb safety. ThAt is just something extra to have to do I you have to pull your gun.
Edited by CJ18
mmk i think im going with the g36.... I wish they had the 45 in a compact but they dont so i will have to go with the Sub compact
Team MaxRetribution
It's not bad actually. I've got it down to one fluid motion, but to each his own.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
The only difference between the Kahr and Glock is the bodies!! The internals are borderline identical! The body on the Glock is stronger but also heavier!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
