I Just got the wood in and planning on starting constructing in a few days. I was going to run up to home depot to get some supplies, but not sure all what to get.
Im going to paint the box black, do i need any special kind of paint? (3/4 MDF)
What should i use for the terminals on the box?
What's everything i'm going to need?
Edited by Jmoney2544
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
I use Rustoleum Stone Accent Paint, when i use regular paint it justs sucks it up and looks like crap, i usually do throw some primer down first though. I also only use 1 1/4in screws pree drilled of course and also set into the wood. i use 5/16 nuts bolts and washers for my box terminals about 2-2 1/2 in long
Basically
Screws
Glue (titebond 2 or Gorrila wood glue)
Some type of caulk for the inside i use something called Lexel
And ur terminals.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
clamps. corner clamps help too. but defiantly clamps.
look at my super internets it beast!
http://speedtest.net/result/906958776.png
Clamps
Titebond II for sure. I buy it buy the gallon.
1 5/8 course thread drywall screws
I use 3/8" lag bolts double nut the wire to the inside, drill a 3/8 hole, slide it through till the nut hits the box, tighten a nut on the outside then jam another one down when you put your wire on it. Seals air tight, and gets a good connection.
ALWAYS ALWAYS ALWAYS predill your holes, I like to countersink mine as well but I wouldn't consider it a requirement.
MDF is notorious for sucking up any type of paint, I use a cheap grey primer for 2-3 coats before I lay down anything else. Also I like to use an orbital sander to make all seams perfectly flush, then use woodfiller on all seams, and on all the screw holes so that once it's painted none of it shows through the paint.
A Jasper Jig and a router will make life MUCH easier when it comes time to cut out your baffles. If not just take your time with a jigsaw and then clean up any uneven areas after.
I use cheap DAP brand clear silicone in all the seams, everyone has their own opinion on what works best but it's never treated me wrong.
Also if it's going to be big enough it wouldn't hurt to brace it. I like using some 1" dowel rods or something of the sort, 2/4's work, 1x2's, whatever you have readily available. Double baffle may also be necessary to add some strength, plus then you can flush mount your subs which looks great.
Take your time, don't rush, don't cut corners. It will turn out as something you can be proud of in the end.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
Clamps
All good advice in my very limited experience.
After you get a bit of experience under your belt, it becomes MUCH easier. IMO, the hardest part is cutting wood.
Then again, I use a circular saw. :D
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Clamps
I bought a 49" straight piece of 1/4" thick aluminum, clamp it with a c clamp on both ends, set my circular saw against and cut. Instant straight cuts for dirt cheap if you don't have access to anything better. Just measure the width from the blade to the short side of the guard and add/subtract that accordingly to get your cut where you want it.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
instead of clear silicone I use a colored silicone, usually black or bronze, so I can spots that didn't make a good seal. also I never pre-drill my holes, I use Spax hardwood screws, no need to pre-drill or countersink as the screw does it for you.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • Who's Online   2 Members, 0 Anonymous, 1130 Guests (See full list)
