DC Sound Lab
Its summer time... Who's amp isn't warm...
Yesterday the amp was fine at "full volume" and today it's not even though you changed nothing? Maybe you blew a mid or tweet... Or just have them hooked up wrong. How exactly do you have your drivers wired?
Edit: reread first post... You probably are clipping bad seeing as the gain is the same but your pre amp voltage is higher... It's probably because of your HU.
lol, mine are about 100 or so. There hot to the touch getting in the truck.
try one speaker at a time and see what happens.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah I'm going to try that out beginning tomorrow for sure. Thanks N8, and thanks everyone else for the quick replies. Ill let you guys know.
I didnt read. But.
Blown speaker somewhere.
As far as the fear of high HU voltage goes....I wouldn't worry about it unless you are runnning it full out all the time. Such as an example of 34/35 35/35 for an Alpine on volume. The headunits I have tested only produce the rated voltage at the last one or two clicks. So I would guess that the un boosted output of your 5v out hd would only be over four volts at the last 8 or 10 clicks. ( depending on what the max number is....60 on the pioneers I'm referring to.) As others have said...this points to other reasons for your problems. Just take your time and test everything piece by piece and you'll find it.
05 tC
6 lvl 3/4 10s
RD D5
2 XSPower D1000s(16v)Thanks Scottie
2010 USACi WF SS 0-600 3rd 157.2
1 DD1508 at 2 ohms 147.5 USACi outlaw, not port
Thanks for all your help Rusty
Well I just tested out the amp again... checked my speaker wire runs and made sure everything was correct. Hooked up individual speakers one by one (4 selenium mids and 2 selenium super tweeters) and they all worked perfectly. I hooked everything up onto the amp and turned it up to 18 of 62 and it went into protect mode. Im going to say IT IS the 5v preouts on the Pioneer deck, thoughts?
How do you have the amp hooked up? What speaker to what channel.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
would yuo not have the same pre out voltage when testing just one speaker?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Once I unplug the speakers I turn the radio to 60 out of 62 and it wont put the amp into protect. The mids are 8 ohm and the super tweeters are 8 ohm. I have the mids wired together to 3.2-3.4 on ch. 3 and ch. 4 ... than each super tweeter has its own channel and sits at about 6.8
  • Who's Online   0 Members, 0 Anonymous, 3762 Guests (See full list)
