I know I've seen this done on the forum before but most of the time with a battery in between. Is this going to smoke my amp or charger? I have it playing on some home stereo speakers and it is suprisingly clean. At first I just wanted to test the amp and make sure it works cuz it was a yard sale find now it sounds good and I want to keep it there lol.
I hooked up my voltmeter to it and it never goes below 12 on rock. Sits at 14.5 on low volume levels. If I put a hip hop track on with heavy bass it drops to 11.5-11.25 on bass notes. This is on the 2 amp charger. If I put it on the 10amp it goes to like 16.5v
I can watch the charger pull when bass hits.
99 4runner - So far: Alpine PDX4.100 & AQ1200D. Needz speekrz yo.
It would probly mess up your charger. Because it's not supposed to give and pull power at the same time
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
"if you gotta ask"........
WARNING: I speak 4 languages, profanity, English, sarcasm & real shit
2003 ford explorer
2 RF T1 D4 15s in a 6.8 cubic ft box
1 T1500.1bdcp
250amp ALT by Mike Singer
2 runs of 0 gauge
3 yellow tops
I wouldn't. jmo
HEAD UNIT JENSEN VM9312
4 12" KICKER COMPS
4 PUNCH 150 AMPS "0NE ON EACH SUB"
2 ALPINE 3522 ON MIDS AND HIGHS
MLA MOD
BIG 3
OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK
2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200"
DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
this...you already know the answer.
you need a buffer between the charger and amp...even a small battery will suffice
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
Really... I think I have an old battery laying around. Been in the shop for a year probably idk if it's still good. I'll try it.
Even if its not that good of a batt try it, if it can absorb a small charge you should be good to go.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
add a battery, even a $50 junker from wally world
Hammerdown... 1%
