Didnt turned out as planned.....
That box suck ass IMO, why expending a lot of money on another AQ2200 instead of just building a proper box?? i would to AT LEAST 3 - 3.5 cubic feet and 56-63SQ of port...
You could try tuning a little higher. Cut the port down a little. Do the math and see how much. Maybe try 38-39hz tuning. Would also make net volume slightly bigger. If no big change try facing them in the trunk. See if it works any better
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
3.5 by 10.25
That's a lot of port. You might be able to. shrink that down just a little to like 3x10.25
and increase your box volume a bit although I don't know if that would be enough to make an audible difference
Yea what do you think would happen if I moved it out of the trunk.
Like if you set your box in the backseat? It depends. You could try building a box and firing the sub/port forward, and sub/port up and see which one is louder. I think you'd see the best results adding more power to the box you've got though. If not, you might as well wall it and have a lot more fun than you are now :popcorn:
Edit: fecupe2001 knows his shit. listen to him.
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
Yea I'll have to move it out of the trunk then what do u think about that?
"SilveradoGoesBang"
http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/
2 FI BTL 18's
CT Sounds 7k
2013 MidwestSPL Finals Xtreme 3 - 1st Place
Sounds like his box IS 3cf. 2 cubes for the subs with a 1cf external port. 2 cubes for two tens is good. No?
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
If that´s the case then my bad, i understood he had a 2 cubic feet box for the subs, sorry about that OP!
Beat me to it... I'd spend the little bit of cash to build a more efficient box as opposed to buying another amplifier and electrical upgrades... Something's definitely wrong with the current box if your hitting those numbers with the equipment you have.
If I am to wall this car off can the wall sit on top of the seats and just go to the roof?
If you want it to it can sit on the backseat, but you'll be limiting yourself on space doing it that way
Edit: And it probably won't look very good :shrug:
Build Log
There definitly something VERY wrong, you should be able to hit a 137 with a single sub and that AQ wired at 2 ohm without much problems!
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
