Do you seal the inside of your enclosures ???
Fish Chris
I mean with like rattle can spray sealent, or gloss paint ? I never have, but I've considered it.
I mean, how pourous is MDF anyway ? I wonder if anybody has ever done any kind of test to demonstrate the difference in a sealed vs. unsealed enclosure ?
I mean, it would be the easiest paint job ever..... runs ? Who cares ?
But is it worth the hassle, or not ?
Just curious,
Fish
I've seen a lot of people seal them on the inside with fiberglass resin, mainly in the seams bit I've seen some do the whole box with it. That is mainly for strength purposes tho. As for glossing the inside of your box, I couldn't tell you if it'll change anything on a meter, but I highly doubt that it would make an audible difference, actually I'm possitive it wouldn't
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Yes, all the time except with resin. It makes all the difference in the world on the meter anywhere from .1-.5 db of a difference. The reason why is it increases the ridigity of the wood when you use it. Most of the time you will get better results with mdf using it then birch ply for the reason of the mdf just being compressed saw dust. Also by smoothing out the inside of the enclosure with whatever you choose you are reducing air drag on the inside of the box. This allows the air to move faster and will result in more spl.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I use silicone rubber....lol
2001 is300Headunit: JVC KD-X50BTHighs/Mids: StockHigh/Mids Amp: NASubwoofer: DC Audio LV4 12"Subwoofer Box: DLDesigns Box tuned to 32HzSubwoofer Amp: AQ 2200DElectrical: NA Performance:SRT Racing intake with ECUHKS Super Dragger 2BC Racing Coilovers
BC 264 stage 2 cams
full head build with BC Valves, Retainers, and springs
Dezod Green Race Header Comming soon/Thinking about<p>Electrical: XS power under the hood (Suggestions Welcome)​Performance: BC Cams,Cam gears, maybe GTE Swap down the lineMy YouTube Channel Subscribe and i'll return the favor!Xbox Live Team Website.My First Official Box Build.My FacebooK
Werent you banned last year?
If you use a good amount of wood glue and then resin the whole box it works great. A lot of people just use caulk
Yeah I just use some good old caulk
BC 264 stage 2 cams
But i think the op is asking about putting some sort of finish on the inside of the box to make it glossier and smoother, asking if that would make a difference in sound
so far...
I heard mdf is very porous suppossedly you can use a strong vaccum and hold a piece of paper through a piece of 3/4 never tried it. I always use resin in the inside of box it seals it and makes a nice smooth finish. As far as making it louder haven't tested before or after with and without sealing it. Logic would say the smoother the service the faster the air leaves the port which is more dbs
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1030 Guests (See full list)
