toadking90 Posted August 18, 2011 Report Share Posted August 18, 2011 That. Amps all run different. A 4ohm off my amp is only 800 I think. 1 ohm is 1700. If I pull speaker wire out ohms are gone. Or is the thing just that cook and doesn't need those to detect distortion? Quote Link to comment Share on other sites More sharing options...
TheyDontWantMusic Posted August 18, 2011 Report Share Posted August 18, 2011 wha?!? Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted August 18, 2011 Report Share Posted August 18, 2011 you are overthinking this. by a long long ways. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
tonedeaf Posted August 18, 2011 Report Share Posted August 18, 2011 What n8 said. Plug it in as per the directions, set without clipping, you're done. It doesn't matter what impedance your amp is at, gain has nothing to do with ohms. It is about matching up to the voltage of your preouts from your headunit. The dd1 just let's you set it as high as it will go without distortion. Ohms is an entirely different unrelated conversation. Quote Link to comment Share on other sites More sharing options...
toadking90 Posted August 18, 2011 Author Report Share Posted August 18, 2011 Ok sorry for the dumb question. Thanks Quote Link to comment Share on other sites More sharing options...
ryan916 Posted September 8, 2011 Report Share Posted September 8, 2011 But what about this, lets say i have a pair of components rated at 150rms and my amp puts out 200 rms at 4 ohm. Is the dd the wrong tool for this situation? Quote Link to comment Share on other sites More sharing options...
SixTwoRado Posted September 8, 2011 Report Share Posted September 8, 2011 I was curious about this too with my small lack of audio knowledge. I know how ohms can affect the system, but I too was also trying to figure out if ohms would affect setting the gains with the DD-1. I was worried cause I have my pdx amp which runs at 2 or 4 ohms. Looks like you guys answered my question though. I just can't wait to get my DD-1. Quote Link to comment Share on other sites More sharing options...
Tarball Posted September 8, 2011 Report Share Posted September 8, 2011 Ok sorry for the dumb question. Thanks The only dumb question is the one you don't ask. I assume you are all the wiser after asking this question...no? Quote CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
armykyle1 Posted September 8, 2011 Report Share Posted September 8, 2011 It wasn't a dumb question. I had the same one, I just researched it a little. My concern was running lower ohm loads, losing efficiency and possibly going into clipping. But the gain on your amp is amplifing the signal coming in so as long its not set to high you shouldn't clip even running extremely low ohm loads. Quote TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 8, 2011 Report Share Posted September 8, 2011 But what about this, lets say i have a pair of components rated at 150rms and my amp puts out 200 rms at 4 ohm. Is the dd the wrong tool for this situation? Set I with the DD-1 then turn your gain down from there. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
