How to set different ohms with dd-1
you are overthinking this. by a long long ways.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
What n8 said. Plug it in as per the directions, set without clipping, you're done. It doesn't matter what impedance your amp is at, gain has nothing to do with ohms. It is about matching up to the voltage of your preouts from your headunit. The dd1 just let's you set it as high as it will go without distortion. Ohms is an entirely different unrelated conversation.
  • 3 weeks later...
I was curious about this too with my small lack of audio knowledge. I know how ohms can affect the system, but I too was also trying to figure out if ohms would affect setting the gains with the DD-1. I was worried cause I have my pdx amp which runs at 2 or 4 ohms. Looks like you guys answered my question though. I just can't wait to get my DD-1.
Ok sorry for the dumb question. Thanks
The only dumb question is the one you don't ask. I assume you are all the wiser after asking this question...no?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
It wasn't a dumb question. I had the same one, I just researched it a little. My concern was running lower ohm loads, losing efficiency and possibly going into clipping. But the gain on your amp is amplifing the signal coming in so as long its not set to high you shouldn't clip even running extremely low ohm loads.
But what about this, lets say i have a pair of components rated at 150rms and my amp puts out 200 rms at 4 ohm. Is the dd the wrong tool for this situation?
Set I with the DD-1 then turn your gain down from there.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 718 Guests (See full list)
