I hear mr car engine as well as my blinkers through my speakers in my car. I can put my volume to 0 and it will still play through my speakers. I hear its something with pioneer decks not being grounded correctly? has this happened to you guys? What should i do?
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
Happened to my old pioneer deck, check your grounds also and make sure you dint have your power wire ran next to your RCAs or speaker wires. Its usually small over looked things
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
well are you running amplifiers or are the speakers directly off the deck? if you have a 4 channel amp, its that ground. a common solution to this is to make a run of 0 gauge from the battery ground to the rear of the car where you ground the amp. i did this personally and it worked great, i have no static or engine noise. and i run a Pioneer 7100BT deck
ive checked all my grounds and there all secure and tight. I have no idea what this could be. Someone at this local shop said that pioneer has had this problem for over 10 years and still havnt been able to fix it. he said to wrap a wire along my rca and ground that.
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
Posted (edited)
Try grounding the chassis of the deck to the ground of your amp, I know its a pain but it almost always fixes this issue
Edited by EBW
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
This what I do with my pioneer deck and it has worked for me.
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
I have the same probams. i have a pioneer avh-4200dvd. i have my back batt. grounded to the frame. a guy at my local car audio placse grounded the rcas at the high amp and it even made it worst.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
you have to ground the RCAs at the deck not the amp.
MechMan 220a Alt
DC 5K
Kicker 650.4
Pioneer DEH-P7200HD
ground your rcas
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
Posted (edited)
Wrap a piece of wire around the barrel of the RCAs on the deck and ground it to the chassis. EDIT:The chassis of the deck.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
