DC Sound Lab
DC 12k Clamp Test
2- 5k or 7.5 strapped would be better for me.
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Im sure its a great amp . The name is just misleading
yes and no, the ouput looks great on it, but you have to wire it SUPER low and be able to run 16v+ to reach its potential
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
2-9k's ray.
Lv5's
Anyone care to sponsor me:-) id slap it in quick.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
i'm still somewhat confused...it's making like 6500w between the 2 channels after rise? i'm really just trying to figure out why it's called the 12k if it's making the same power as the 7.5k...(if i'm reading all this right.)
I am going to be clamping my 7.5k twice. Once tomorrow to see current power and rise and once in about a week once the subs break in to see the change.
he is getting 30hz 44a 71v 3124x2 @ 1.61ohm per channel
thats 6k
not 6k per channel.
he was wired at .5 per channel.
he would have to wire down to .2 or so per channel in order to get 12 clamped.
I will actually be trying this once my subs break in. I have a final .66 ohm load which I can bridge and see .33 per channel. I am running 14v batteries so I will be able to regulate my voltage to see the power at different voltages.
It is not recommended to run the 12k any higher than 16.0v.
Ray why so much negativity towards this amp?
I cant remember amperage or voltage (ill see if i can get this later on)
but at 40 htz with my 12k wired to .25 ohm bridged (not per channel) i had a 1.7 ohm rise and got 6405 watts out of it and scored a 156 in the kick. before when i had my 5ks strapped at 1 ohm i actually put out MORE power had about a 5 ohm box rise and hit less of a score. more power doesnt always mean more DB. i was able to get 7700 out of my strapped 5ks at 1 ohm and almost a 5 ohm rise and i was only hitting mid 154s in the kick.
NoFearX18 said:
trainman0978 said:
Didnt see me being negitive.
So... You burped it at .125 per side??
Rise to .85 per ch and only got 6k?
Thats not my cup of tea
Like dc, rep dc whatevee. Im lookin at $ per watt clamped
Thats all. Your spittin facts and im just being real.
