Smart cars!!!!!! So little airspace to move ftw. :) lol. Good luck finding a spot for the sub though :) lol
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
ive been leaning toward a blazer they have alot of room and i can fit 24s on them lol
they are pretty nice, the thing i hate is the gas but putting 24s on them is a plus. i have some for sale that would fit right on :ninja:
Dude ! Look no farther ! THIS is what you need :)
Talk about holding in your SPL's !!! :) Bullet proof glass is standard too ! Plenty of space for a dozen 18"s.... A big diesel motor which set up correctly, could probably make about 3000 amps ! Great way to get started ;)
This would be "The REAL" stereo wagon :)
Peace,
Fish
Right now I have a 2004 ford escape and have horrible voltage problems. I have a sprinter bat in the back and a yellow top up front. I cant do the big three because I would have to drop the front axle. What is the best vehicle for car audio besides a van? I need easy access to the alt and alot of room.
Tahoes and like gm vehicles are by far most common. Plenty of room for Alts. Lots of cargo space. The only downside IMO is everyone has one.....
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
i have 1995 Honda passport and i have been told it is a good stereo truck...put a mechman alt on it all i had to do is stretch the alt bracket...lots of room under the hood and my windows are pretty straight with little curve in them ...side to side it is 49"@wheel wells .i have x2 sundown sa 12"s doin a 145.4 in a midwest legal spl box on music(i think im a 146 since my subs broke in) i run a hifonics hfi2500.1 with 3 extra batts....truck books for $1700 ude with 160k mile so its a good cheap system truck .........hope this helps cause i know i like my truck and its 17mpg
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
Wouldn't dropping the front axle be far easier than buying a different vehicle?
2004 Ford Truck Escape AWD V6-3.0L VIN 1
Vehicle Level Starting and Charging Charging System Alternator Service and Repair
Service and Repair
GENERATOR
REMOVAL
Disconnect the battery cables.
Remove the right intermediate axle shaft.
Remove the right lower splash shield screws and the pin-type retainer.
Rotate the accessory drive belt tensioner clockwise and remove the accessory drive belt.
Remove the nut and position the bracket and wiring harness aside.
Remove the upper generator mounting bolts.
Remove the lower generator bolts and position the generator aside.
Remove the generator mounting bracket bolts and remove the bracket.
Remove the generator electrical connectors.
1 Remove the B+ nut and cable.
2 Remove the connector.
Rotate the generator to gain clearance, and remove through the opening in the fender well.
INSTALLATION
To install, reverse the removal procedure.
calls for 2.3 labor it is a B**ch but do able i got bored and looked this up on alldata
Edited by extremeauto
kenwood mp3 usb
hifonics mx-3
13.2 cube box/wall
massive DB8000
big 3
still upgradeing!
