DC Sound Lab
Some of you know of me and my setup. I run 4 xl 18s on 2 dd m4s strapped at .7 so about 10 to 12k @14v.rising from .35 a amp to 1 ohm. Well I'm stepping up to lvl 5s in same box. Should I get 1.4 coils and run 2 dc 5ks strapped @.7 for around same power. Or dc 12k at .35 per channel. Or d.7 coils and run 1 dc 9k @ .35 with th option to add another later.what do you think would do the most power and why. Once again 2 5ks, 1 12k, or 1 9k
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I know my opinion probably doesn't matter, but I'd like to see the 9k, if you do add another later on. A 9k per pair of Lv5s would slam lol...
You'll have issues with the 9K running that low... It doesn't like anything below .5 ohms... :drinks:
You think boiler? I've seen a few guys burp them at .25 I'm thinkn that if my dds do daily at .35 the 9k should I'm just trying to get the most powere out of it since my rise is .65 it would put me at 1ohm and close to 9k or more @14v
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I would not waste the Level 5s on a single 9k or 12k. I have 1 12 running on 4 XL 18s in the mini van. I am running it at .5 ohm per channel and getting just over 3k per channel from it at 12v with rise to about 1.5 per channel. For it to be worth stepping up to the Level 5s I would look at running 1 5k per sub for 4 total or 2 9ks. I know the 5ks will run just fine at .35 nominal and I believe Blake(truelywickedcustoms) is running his 9ks pretty low. One thing to remember though, running under 1 ohm you are not covered under warranty if the amp goes up in smoke.
2 9K's on 4 - Level5 18's sounds like the best bet to me!
So are you selling the DD's and the XL's?
Edited by Purplehaze
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
i like the 2-9Ks ideah. or even 4-5ks
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
  • Who's Online   0 Members, 0 Anonymous, 1734 Guests (See full list)
