*5/19/13 Vid!* and some *SURPRISES!* coming! 95 Bonneville SSE Walled (DC, Cactus Sounds)
Lookin gnarly as always!
thanks brandon!
whats your end looking like??
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
How do you like that volt meter ? Does it have a bottom to turn it on and off in the display ( so no switch will be needed)
i havent hooked it up yet, but i have my old meter on a relay.
the button on the new meter is to change settings amp/volt
HMU!!!
95 Bonneville SSE
hopefully an update vid today
HMU!!!
95 Bonneville SSE
thanks brandon!
I'm still waiting on my sub to arrive :/ tryin to find some 1/0 cca for fairly cheap. Need fuse blocks and terminals too.
My old Build Log!
http://www.stevemead...der-in-a-jetta/
Two Obsidian 15s V2
Two Audiopipe Apsm 1500s
Fourth Order Wall
TEAM CLEARLY LOUDER
TEAM OBSIDIAN AUDIO
audiotechnix!
thanks brandon!
HMU!!!
95 Bonneville SSE
Update:12/19/12
ordered some audiotechnix 1/0 CCA wire.
i removed the amps and rack out the trunk to find what was wrong with one of my + wire runs.
it had a bad ring terminal connection.
so im going to add another power wire run and ground run.
i used this camera to see behind and closeup of the faulty wire
HMU!!!
95 Bonneville SSE
That camera is nifty!
it is!
we use it all the time, its a life saver!
wehn am i coming up to your place
HMU!!!
95 Bonneville SSE
