Where do people learn about electricity?
From a conversation on about busbars vs. 0g to connect batteries.
but useing buss bars makes all the batts as one huge batt. it also lets up put the power from the middle of a set of batts instead of a single batt. when the batts are sitting at rest thy are holdiign a charge in the mass of the metal so imo bussbars better for this,, wire will not store d/c voltage in needs to wait for the demaind before it will carry the load. with wire also imo the wire goes big to a little ring instead of all the charge be held between all the batts like with bussbars with wire the el3ctrons will go from one to the next to get to the load sorce (amp) i have meanings be hing this but hope it makes a little sence i forgot what i started saying
So I guess, busbars are the new caps?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
:orly3:
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Haha wow, metal is metal, don't matter if it is a bar or round wire, conducts the same, in dc conductive metal doesn't have capacitance like it would in a AC environment.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Explain capacitance in a ac enviroment sir? The use buss bars in every panel I've seen to distribute power to breakers. I think buss bars for batterrys is cleaner looking more efficient and allows current to flow easier yes.as far as all metals conducting the same. Not even close. For example stainless and brass are low on the list. The least corrossive ones usually are. Stick with copper and aluminum. Or have some gold ones made up if your balling lol
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I don't think he was saying all metals conduct the same, I think he was saying neither busbars or wires store, both conduct.
F150:
Stock :(
Processor: DSR1
I want to know where he said every metal is the same...or did I miss my stupid pills this morning?
You slightly missed what I said, a bar or wire will conduct the same, one won't conduct electricity better then the other. If there is the same amount of metal there and they are the same type of metal they WILL conduct the exact same. I would know being I am an electrical engineer lol.
And for AC, because of the alternating current and the reactive component(VAR) then you have capacitance, and if the line, wire, bar is big enough and long enough with will act like a capacitor. One example is in transmission, if you have a 345kv line that is 500 miles long and open ended, the voltage at the open will be higher then the voltage at the closed end. You get voltage rise due to the capacitive nature of the line.
Evo X build log
Explain capacitance in a ac enviroment sir? The use buss bars in every panel I've seen to distribute power to breakers. I think buss bars for batterrys is cleaner looking more efficient and allows current to flow easier yes.as far as all metals conducting the same. Not even close. For example stainless and brass are low on the list. The least corrossive ones usually are. Stick with copper and aluminum. Or have some silver ones made up if your balling lol
fixed. using gold would be stupid. less conductive than copper. only reason it's used a bunch is because it doesn't corrode as fast as the others.
Eclipse cd7000
lol ya, the COPPER buss bar acts WAY different then the COPPER in the wire.
i dont understand the appeal to gold connectors. gold ranks under copper and silver ranks above copper. plus silver is cheaper. why dont we see silver plated connectors?
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
