best trunk
if you do it right you can pull everything out and no one would ever know.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
from my previous testing ive had best results on the METER with subs and port firing back, now i have had the best SQ with subs and port firing into the cabin sealed off, for some reason the lows i get are phenomenal, you would think it'd be the other way around but for some reason i lose the authority of the lows from about 28-33hz in that range when firing back
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
I've done subs back port up and had canceling issues that made it sound like crap, then I went to subs back port back and that's been my best luck so far. My back seats don't fold down so I'm at a little bit of a disadvantage there.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
from what I've seen subs back port back, I did a few different things in my car and that worked best. But sealing off firing forward seems to gain tons. I saw one guy who did this with 12s went from 145s to a 148 same box and all
See that's the thing, I'm ok with installs but far from great. I like to do things myself, I refuse to pay for something I can do, only problem is I'm not 100% confident in myself when it comes to some stuff lol. Since I've never done it before I really wouldn't know where to start. You wanna help, I'll listen!
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
I like subs back port to side. That has always been the best for me on the TL and daily.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
i went from playing only down to 28hz to down to 20hz just from sealing forward.
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
I'm forward firing sealed off and I can get it out in a couple hours. I have to remove my passenger seat and the center console, though. I guarantee i'm tighter on space than you are.
Start by making a panel that fits the opening (facing forward) as neat and tight as possible. This will be the template you use to sketch out your baffle layout and determine what size subs you really have room for, and if you have room for the proper port size.
SMD Super Seller
My Feedback Thread
exactly, i could always play down into the low 20s, just not with much authority
firing into the cabin my car really likes that 27hz up to about 33hz, would move so much air and shake so much shit, now when i play it.. it still plays down that low, just not with much authority... rarely can you ever have the best of both worlds :shrug:
Team Sundown Audio
Make a templete out of what cardboard or something? I've always heard of people using expanding foam and stuff like that to seal off a trunk, that's why I was saying that I didn't want to. But any help you give would be greatly appreciated. thanks
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
