I'm pretty damn good with math, I'm building a box 31x13.5x20.5 with a slot port of 13.5x4x23.5 and sub displacement of .28 total. Torres put my box at 3.59 net tuned to 37.xx. And yes I did put in the outer dimensions for the box as Torres ask for, 32.5x15x22 with 3/4 MDF, last time I checked my box comes out to be 4.96 gross and 3.98 after displacement. Either Torres is wrong or I am??
Edited by miniSPLlancer
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
also depends if you put the port walls in correctly, depending on where the port is could add or subtract some from the volume.
Torres is correct, there is a reason it is pinned and many people use and recommend it.
your first post is just a mess with all the numbers, your building a box thats "31x13.5x20.5" yet your putting in "32.5x15x22" ???
just throw these numbers in:
h=15
w=32.5
d=21
port:
h=13.5
w=3.5
l=18
misc:
displacment = .28
common port walls = 3
specs:
3.75 NET
12.60" of port per cube
36.54hz tuning
i'd recommend a 21" port for 35hz tuning though, but thats what ive always tuned my trunk boxes to and always saw great results.
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
h=15
w=32.5
d=21
port:
h=13.5
w=3.5
l=18
misc:
displacment = .28
specs:
3.75 NET
36.54hz tuning
Torres ask for the outer dimension, not the inside, that's why it ask for the thickness of the wood .75" so that it can deduct that from the outer dimensions.
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
h=15
w=32.5
d=21
port:
h=13.5
w=3.5
l=18
misc:
displacment = .28
specs:
3.75 NET
36.54hz tuning
yes i know that, i get it now you were using your own math, which is where inner dimensions came from
use the numbers i gave you, it'll work great with the SA12s...
Team Sundown Audio
h=15
w=32.5
d=21
port:
h=13.5
w=3.5
l=18
misc:
displacment = .28
specs:
3.75 NET
36.54hz tuning
I'll give a try thanks, just trying to get all I can out of it, I clamped my amp today and something is wrong, I'm assuming it's the box, my lowest ohm was at 30hz at 54 volts and came out to be 2.98ohms when the subs are wired at one on a crescendo 2000, I'll try yours and hopefully that'll work better for me otherwise it's back to the drawing board lol
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
