no fit..
I dont see it anyway.
1st Impression:
Without a wall, or above window line I dont see it goin down.
I have the same gen integ and unless u go above window line I really have a hard time seeing 3-18's with proper air AND fitting them giant RF amps and some Batts to run em.
Mind you-I think it IS doable, just gotta use EVERY tiny bit of air in there.
Spare tire well galssed, entire trunk glassed, rear seat area used and walled I can see it. Otherwise I don't think there's enough surface area to fit 3-18's-Horizontally or otherwise.
I'mma go play around in my ride and I'll get back to ya if I can fig it out but not till some serious numbers are crunched.
"In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno
Good luck doood! Lets see it!
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
after seeing those pics of his 15s, its totally doable
I say fiberglassed 3- 18s 1 facing each person up front, and one apposing in the back (against do to cancelations) but for wow factor, and lows it would be cool, for SPL, high numbers do 2- 18s, 1 behind each seat, (or facing up if need below window line) port way in the back, that way would be easiest, and probably be most benificial, DB wise that is- Totally doable, easy 2- 18s, 3- 18s, a little sticky, will work, but subs would be at all different angles- Airspace, not worried about AT ALL....
Poly fill can fix that, wont gain in SPL, but will help the low end, and lack of airspace, and actually cause the speakers to play a flatter freq response for a SQ set up. And Iam still seing below window line
I say if you want to get LOUD and LOW, just do 2- 18s, wild and fun, 3- 18s
I agree w/ forevrbumpin to some degree-
I think 2 is doable and would be sick loud....but consider this:
A sub will play in ANY configuration- big box, tiny box, even free air. Mount it, Apply power and it will make some sound. What were talkin bout here is how well/efficient it will play in a given setup.
You could TOTALLY just glass the rear seating area, trunk and all and keep the setup below window line, and either squeeze 3 18's in there staggared kinda pointing forward or go 2 forward and one up.
Just run em in whatever space ends up (net) in the giant enclosure. They will prolly end up a bit UNDERSPACED due to the tight area, but that would just mean they would sound punchier and as Forevr pointed out more "SQ like" or accurate due to having the effective "tighter" suspension (more resisitence in the smaller air volume). Prolly not "ideal" or "typical" sound for an 18" beast but I bet it would still sound damn nice and IMO BETTER due to the improved transient response. If you kept it sealed it would also be more easily done but I'm SURE you would want it ported and in that case I would consider a design like Pstones in the "Flying White sausage" (jesus did i just type that?) or roscoe's setup w/ the xxx 18's or Assman's van where the port is the "negative" area around where the subs are mounted. I think that'd be ur best bet if you absolutely had to port it.
~2cents.
Edited by LSN2meBoom916
~2cents.
The wheels are spinning arent they. If I do it, I would like to face all the 18's straight up towars the roof.
Official Scores at the Dash. and YES. My Bass Boxing is louder than Burp! - 155.5 DB Drag Burp- 155.6 - IASCA Bass Boxing on music (30 seconds straight) sealed up Builds 1. The Acura Integra build = http://www.stevemead...s/page__st__6802. BLK SIN Build = http://www.stevemead...w-pics-10-6-07/
sunroof? put those amps in the ceiling and look how much more space just opened up. I think it can be done but it will be spendy.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if stuck doing a smaller box, it doesnt mean its not right for the subs, you just need to down size the port size to compensate for loss of air space, so if you were expecting to do some 150sq inch port, maybe should re thingk a smaller box, and port down to 100-90sq inch, and everything will be perfectly fine, hell again, like I said it already, atleast just line the walls in the box with about 1"- 2" poly fill or fiberglass to trick the subs in to thinking they are in a slightly larger box... I knew from the beggining this was a possible set up, 2 or 3-18s, hell i have built and installed some 18s for a guy that only needed about 2.5cf of airspace, did a small area port, but long, and it was sounding amazing
Hell man, do 2-18s in a Horn loaded wall fuk a box, get REAL loud ( I know your loud as hella already I felt that thing with the 12s from a few years back) but how many people do you know who have a walled off horn compact car? I dont know a 1, That just means there is room for a 1st
I think 3 18's would be sick and different from everyone else.
i think it could be done . get creative .... rough ride to go the easy way, put some alum blocks under the rear to keep the ass from sagin, then gut that bish out from the b pillar back, have 2 18s faceing the front (one behind each seat of course) the 3rd have faceing the roof ulitise the spare tire well, i can see 20-23 cubes before port and sub dis.
and since youre going extreme finaly put 1/2 mdf on the roof, back fill with foam to make the roof rigid , cover the mdf with fabric of choice, mount your amps on the roof and with them there they will stay cool , from the air blasting by with each beat and so forth, ....go for broke
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
