what makes a subwoofer louder? - scientific
ok ive been trying to thin about this and i would really like to learn the science behind it. if you take like a 100 watt 12" subwoofer and a 1000 watt 12" subwoofer ... what makes them louder? their both 12" cones moving air so what really makes them louder ?
Mostly the motor, but here are some others: High sensitivity ,High thermal power rating, large mechanical stroke = high displacement...
UNDER-CONSTRUCTION
''Old School Build''
maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box"
190 db when your done?
Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it
lmao
There was an anology explaining this to me sometime back.. say you have a 12 in shovel and your pushing snow. Well the 100w sub will push it say 2ft were as the 1000w sub can push it 10ft. I think it has to do with motor force and cone force. Someone tell me if I'm wrong
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I would thinks its a combination of coil,motor force, suspension, and cone structure..imo curious to know for sure myself!
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
it all has to do with speed and the amount of air the cone can move
the more air the sub can manipulate the easier it will be to get loud (basic principle behind cone area is king)
the speed though is the trick and honestly that part i havent quite figured out yet. but there is a reason why if you put more power to a sub (even if it was at xmax on lower power) it will be louder
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
When u say 100w an a 1000w ur powering them with the same power each if not then the difference will be power. But that's a good questions I would also like to know the answer if on same power.
Running an alternating electrical current through a coil of wire will produce a varying magnetic field.
That magnetic field interacts with the speaker's permanent magnet and therefore pushes or pulls the cone.
The 1000W sub can handle more thermal stress so therefore you can provide the sub with more voltage which induces more current.
The more current through the sub will produce a stronger magnetic field which can react quicker with the permanent magnet.
Efficiency of the sub also plays a big role so you make use of that power rather than just burn it off in heat.
Since the 100W and 1000W subs have the same cone area, then to be louder the sub needs to move more air.
Of course the enclosure also affects how far the cone can travel and its tuning frequency.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
The key principle in making sound is how much air can you move
Most of what makes a sub work has been said, but I think it's like this:
RMS Rating = How much power a subs coil can handle
SPL 1w1m = How much sound it will reproduce with 1 watt
Sd = Cone area, how much surface radiates sound
Xmax = Stroke. How much away from rest the cone moves to sweep air
Fs = natural resonant frequency of the sub... typically can help indicate how low it will play, but don't take this literally, much more is involved here!
BL = motor force available for the coil to "work on". If you have a weak magnetic field, all the power in the world won't do shit for you.
So those are the ingredients, you just have to figure out in your mind how they work together. The more air you move, the higher the SPL. The fun part is when you apply these characteristics you might expect one reaction but get another. Add to that how each manufacturer measures everything differently... well have fun with that.
2007 Pacifica
  • Who's Online   0 Members, 0 Anonymous, 1262 Guests (See full list)
