Ascendant Audio SMD 18 and 11,000+ watts! UPDATED!
So I started the box for the single SMD 18 today.
It will be powered by these 2 little amps strapped at .7 ohms daily (.35ohms per amp)
More pics in a few minutes once uploaded from phone.
So rough box specs are:
Sub up, port back.
12.2 cubed external.
7.8 cubed after all displacements (woofer, port, 45s, etc).
15.01 sq inches of port per cube.
28hz tuning.
Also will have some random vids of assembly which I have to edit of cutting wood and what not. lol
More pics:
The start of assembly
Top baffles set on top
The front of the box
1 inch thick acrylic 12" by 24" (actual window will be a tad smaller)
Marking the front panels for the window
Cutting the window
Looks like a nice clean cut :)
Test fit
I ended up marking the height of the window on all 3 piece too small. So I will have to go back and fix that tomorrow before I cut the other 2 pieces for the front of the box. I ended up not dividing the needed height in half but at least it was too small and not to big, so no wasted wood :D
Tuned in
