TheNewbie Posted November 30, 2011 Author Report Share Posted November 30, 2011 Nobody vacuum seals boxes; that would pull the woofers' motors into the gap. Done properly, boxes are air tight though and will wheeze a little when the subs are pressed in slowly. ^ this is what i was wondering. So noone ever does it. Thanks haha. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
santo Posted November 30, 2011 Report Share Posted November 30, 2011 what? that could be interesting to try up in space? Link to comment Share on other sites More sharing options...
Tarball Posted November 30, 2011 Report Share Posted November 30, 2011 what? that could be interesting to try up in space? There is no sound in space. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
ALPINE408 Posted November 30, 2011 Report Share Posted November 30, 2011 the foam surround on a sub is porse and will leak air and if ts a rubber surround and you did vacume seal a box it would suck the cone down and keep it stuck there like haveing your hand push the cone down then play it... it wouldnt work Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
CHEVY4X4BLAZER Posted November 30, 2011 Report Share Posted November 30, 2011 Wonder what a 1000 watt 20 Hz signal would do to a sub in free vacuum. O_o Link to comment Share on other sites More sharing options...
STEvil Posted December 1, 2011 Report Share Posted December 1, 2011 the same as in free-air, make the cone move forward and backwards, although slightly easier due to less atmospheric content. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
Kranny Posted December 1, 2011 Report Share Posted December 1, 2011 Wonder what a 1000 watt 20 Hz signal would do to a sub in free vacuum. O_o it would probably move but wouldnt make a sound whatsoever. Link to comment Share on other sites More sharing options...
412 CVX Posted December 1, 2011 Report Share Posted December 1, 2011 what? that could be interesting to try up in space? There is no sound in space. this is going in my sig! Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
Kdub26 Posted December 1, 2011 Report Share Posted December 1, 2011 I can honestly say that's the first I've heard of a vaccum sealed box lol. I wouldn't try it though. Unless I had the time/money/boredness 1992 Camry "Stormtrooper"Quantum Audio DVD/USB/AUX 3.5" single din H/UXS D690Cadence 0g wiring and Kicker 4g wiring(2) Selenium 6w4p's(2) Selenium ST200'sKicker 200.4 (mids & highs)(1)Kicker and (2)Stinger RCA'sSecondSkin in trunk and doors12K HIDsMulitcolor Angel EyesSoon to be done:Big 3Mechman H/O Altsubs?amp? That thing is going to eat people nearby cars, unsecured objects, and small childrenFixed!wow nice. i wanted nos on my car but the gf said no. i was just gunna do a 50 shot tho hahaGet a new girlfriend. Link to comment Share on other sites More sharing options...
pstone11 Posted December 1, 2011 Report Share Posted December 1, 2011 Well, figured that one out... locked up! Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page! Link to comment Share on other sites More sharing options...
