Car died, wont start. Help =(
I was driving today, going about 15mph and my car just shuts off. When I tried to start it back up it acted like the battery was dead, the starter sounded weak. So I called my roommate to come give me a jump since i was only 2 blocks away. We tried jump starting it and it did the same thing, so I figured my front battery was finally toast. I had it towed home and went and bought a new battery. Just installed the battery a few minutes ago and its still doing the same thing...WTF.
The starter sounds weak and then stops like my engines on a bind or something. Any ideas?
My cars a 2000 Pontiac sunfire 2.2L
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Whats the voltage with ign on and when you're cranking?
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
a bit dangerous, but try jumping the wire on the starter....from the main power wire to the selonoid (pocket screwdriver or something). Leave the ignition off, you just want to see if it turns over freely.
There is no way a new battery died in a few minutes. without more diags its hard to say but you may have a starter going bad.
EDITED
Oh, and double check your ground. I have had to remove the rubber shield around the stock ground cable to the battery post before. It wasnt making good contact (another GM).
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
bad starter won't cause it to just die while running :)
No distributors on this engine, coilpacks
NVX LOC
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
I'll get that measurement tomorrow when theres someone around to watch the meter when I crank it.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Could be CPS, timing belt, or electrical short.
NVX LOC
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
yeah, good point. I was just about to edit my post about that.
OP - did the car ever start from jumping it ?
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1478 Guests (See full list)
