Hifonics brz2400.1d keeps frieing every few months..
guimond47
Hello i have the hifonics brz 2400 and its pushing a fi btl and i do not use the bass boost noob and my gains are set corectly. The btl is a true 1.7 ohm dual vc so its parelled down to .7 ohm which the amp shouldnt really see because of imp rise.. And as for the electrical system i have dual batts 1000ca each and big 3 upgrade with barely any volt drop wen deiving and stuuff. What is going on with the hifonics line up,? Brz's should be solid amps...
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
Do you know what your actual impedence rise is? I've always been told that you should never rely on impedence rise unless you have a straight spl system. Additionally what kind of voltage drop are you seeing?
how are your gains set? just for the sake of knowing whats correctly to you;
Either your NOT setting correctly or you have terrible luck.
they are soild amps but are not meant to ran @ under 1 ohm...some will take it but you cant have ur gains crankd up and you have to feed it plenty of power...and not to be a ass but useing reg car batts is not going to do much for you(i figured this out when i ran x2 hifonics bxi1608ds with 2 xtra batts(both reg 750 cca batts)i never hurt my amps but i smoked a 200 amp alt and then pulled it all out. anyway what voltage are you seeing under a load? do you have good enough grounds?
im not sure how ur doin this cause i have 2 fi bl 18s @.5-.7 ohm daily on my hifonics hfi2500.1 witch is the shity hifonics line and i have had no issue's so far...knock on wood...lol these amps need 12-14 volts at all time to run safely other wise they will get hot and shut down...did urs go into protect alot be4 it blew? mine only does when i play with my gains and it distorts...
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
imp rise wont save an amp from a low nominal load. it will constantly see .7ohm.
where is the amp mounted? is it on the box?
Stock amp and 2400W and barely voltage drop, that's kind of weird. What is your voltage?
Like the forum asshole said :P, how are your gains set?
What kind of wiring do you use?
Where is your ground located?
you do know everytime your sub stops moving there is no imp rise and it gos back to .7 ohms so your amp does still see .7 ohms even if you have imp rise even inbetween bass drops it can drop back to .7 ohms
Umm i barly have volt drop because its a. 6.5 diesel motor wit dual batts and alt is the bigger stock and gains are set to voltage output of the deck.
oh gee someone running under recommended load is blowing amps like popcorn. Gee golly cant imagine why cheap amps would do that.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Well then how would
I run my btl properly wit this amp?
  • Who's Online   0 Members, 0 Anonymous, 1754 Guests (See full list)
