Tahoe/Yukon Guys; How's This Deal?
maintenance history is a key part of longevity. change the oil every 3k or 3.5k miles is a big part. My truck which is a 95 chevy has 220k on the stock motor, but got a new tranny about 70k ago. The only bad thing is there are certain parts like the tranny where you wont see anything wrong, then it will shit on you after a year. Hopefully that isnt the case but that price is alright, i personally would need to thoroughly look at it and see carfax.
edit: i change my oil every 3k and my truck literally runs like brand new. even after 3k on the oil, it is still gold/copper color. :shrug:
if you do buy it get a trans flush and make sure they replace the trans filter as well ther is a GM additive that may need to go in as well when this is done to stop wear and friction. most vehicles require a trans flush every 65k another thing is if it has Dex-cool be sure to change that.when dex cool goes bad it likes to eat the gaskets out of the engine... G.L it looks like a sweet truck
:good:
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
its a pretty good deal. but not as great of a deal as i first thought. its only 2wd.
but if that doesnt bother you then id go for it
Not looking for 4wd. No need for it. If I get this truck, its purely for audio.
SMD Super Seller
My Feedback Thread
honestly trannys are the big things that like to go on these. Climb under neath and check for rusting frame etc any leaks from the rear bell housing that type of thing. definitely run a carfax. that price is decent but not too good to be true.
N8 have to remember where we live. We live in so cal so rust really isn't an issue here. But still always a good idea though since you don't know where it's been.
formerly known as Blue86f150
this sux camel dicks
Ya I was gonna say I know the vortec engines when taken care of run for a long ass time. Take it for a test drive and kind push it so its a big shift and make sure it shifts smooth. The tranny is usually the weak spot but since it is 2wd not 4wd that might change the wear and tear. But take it for a spin and see how it feels.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
I would jump on that deal bro... The tranny's will run forever if you keep up with them... My buddy has a yukon that has close to 320K on the original tranny
Team MaxRetribution
Si Vis Pacem Parabellum
:good:
Yes watch that.. it eats through the water neck at the top of the intake... happens so much the nipple is in the HELP isle at the parts store.
If it breaks off you have to clear the threads with a HUGE tap.. Thank goodness the full set was cheaper at grainger than just then needed single tap.
Go the junk yard and grab yourself some extra dash AC/Heat controls.. trust me on 4th set since 04
