i think if someone designed a box made completely out of 2x4s it would look sick. like 2x4 make up all sides and port (if your using slot port) 2x4s glued together and held together by threaded pipe. would def. be thick enough...... any thoughts?
i just thought of that this a.m. while smoking my "wake up" bogie.
thinkn bout doin this just for fun....talk about unique though.
maybe ill sketch something on paint to give a general idea..... nothing fancy just a scribble or two :)
pros?
cons?
IN blue says: threaded pipe
in red says: glued joints
also would require more 2x4s just didnt feel like being all technical lol
Edited by 95legwagon
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
to whoever moved this..... thanks for moving instead of deleting :)
appreciated!
/ LOL
big 3
2x4 framed walls. if you look you can find some. its pretty common. cant beat em for cheap reinforcing.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
maybe we are thinkn bout the same thing but i was thinkn nothing but 2x4s..... like thats the only wood you would use.
/ LOL
big 3
you could if you really wanted to. Id think it would be susceptible to leaking. so youd have to do some serious glue jobbing or resin and matting the entire thing anyways.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Do it fiberglass the inside of the whole thing to make sure there aren't any leaks and post up the pics!! I for one think it would be quite different from anything I've seen..
Laying frame soon.. System has to wait
I'm sure it could be done, but to do it so it doesn't leak you'd spend at least double the money to get it done right. Between the fiberglass, the sealer, threaded rod and nuts you'd be spending a lot more money than you would if you just used mdf.
2001 Blazer ~ (2) 10" DC lvl 4's, Orion 2500d 148.9db
2005 Astro ~ (2) 18" DC XL's, Atomic 5000.1 153.9 db
New England SPL
NESPL - YouTube
That. You'd have to fiberglass the unholy hell out of the seams, corners, and joints. But after that, it should be fine. It would look sick with a stained finish on it. Another thing to look out for is knots in the wood.... One good bass drop would blow those fuckers out.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
