XS Power
Just wanted to chime in and say the XS Power is awsome for putting this together. It looks like I won't be able to take advantage because I'm going with 14v batts but for everyone else...
get 'em while their hot!!
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
does anyone know if the d3100 and the xp3000 can be busbared together? like if the all mount up the same?? if not does anyone want my 2 d3100's lol
Can we get this answered?
Is there any special at all on the d series batteries
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Posts are in different locations. They can be buss bared together, but the post positions are different.
I see that you say not to use these under the hood, probably because of heat. In my minitruck all my batteries are in the bed. Would it be ok to use these as the only battery source for the vehicle. Would probably have 3-4 of them back there.
Hmm. I have until March to decide huh? Excellent. I'm not too sure if I want to invest in my 1999 camry xle v6.
Never done a group buy at all. How do I put in my order? Just looking to do a single xp3000.
Feel like im asking a dumb question but Im no battery expert by any means so here goes:
Is it okay to use only one of these as the only battery in the car considering I will be removing the stock battery as long as it is located inside the car?
I guess what im asking basically is it okay to start the car with a xp3000 all by itself? Just asking since it says designed to be used as a secondary battery and not to be used as in starting applications under the hood which leaves a little gray area for cars with inside batteries.
Going to run 2,000 watts or less and have factory 150 amp alt.
