So I've recently had done bad issues with my spark plug wires. It seems that oil gets inside of the valve and messes with my spark plugs. The wires never sit flush anymore and just today I'm coming home from Osh when I start noticing a sputtering engine and a loud muffler. I get home, pop the hood, and see white smoke coming from my exhaust manifold. 2 of 4 spark plug wires are sitting 3" above the block. I have a feeling my valve cover gasket is bad and is leaking oil into the spark plugs. What do you guys think? Thanks for any help.
-Cody
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Yup it's the hemispherical valve cover design. And there is oil in those. So it's the gasket?
under construction
u hate c-fizzy?
Sounds like your valve cover is leaking and its causing your plug wires to swell up, common to an extent but you never what to get it that bad lol.. what kind of car is it by chance? I would try and get your valve cover re sealed as soon as possible.
Team NWSPLUPCOMING BUILD (when I afford it)
2013 Ford Focus Hatch
2x DC lv3 15s
2x b2 quotas
XS batts
DC power alt
That amp would fuck the shit out of those subs. It would roofie them, knock them out with chloroform, then make sweet, gentle, anal love to them all night.
92 Toyota Celica gt. Alright guys thanks. I appreciate it. Gaskets are like $6. But the it'll take a bit huh? Lol
under construction
u hate c-fizzy?
yeah it takes a lil bit to do.. the service techs at the dealership i work out, usually takes 2.2 hours flat rate to do.. but make sure you clean the fuck out of that valve cover before you put it back on lol
2x DC lv3 15s
2x b2 quotas
XS batts
DC power alt
2hrs to do a fucking valve cover gasket on a i4 engine?
More like 30 minutes.. pop off valve cover, clean off old gasket, replace with new one, re-install, DONE.
Never underestimate the overcomplexity of what should be a simple job. Not to mention the noob factor. If it's the first time doing it, it may take at least twice as long.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
