I have a Hifonics BRZ2100.1D mono amp it says its stable at 1 ohm. I will be wiring it at 1 ohm to a dual 2 ohm fi BTL 15 and I just noticed that the BTL is 1.4 ohms a coil which technically wires down to .7 ohms. Would this amp be able to handle running at .7 ohms in that situation or would ohm rise come into play anyway. I have a 270 amp alt and all 0 gauge with stock batt plus a kinetic hc1400.
Thanks.
/////////// Yes i know that the BTL can take more power and that I won't get the full 2100rms because of setting amp gains to a clean signal.\\\\\\\\\\\\\\\\\\
Im by no means an expert but from the things I have read you should be ok
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
You can i have the brz 2400. but if u dont see over 13.5 volts ur gonna fry them like pancakes..LOL
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
I know a guy here with a BRZ2400 on a sp4 dual 2. 1.3 ohms per coil, 0.65 in parallel. He has a stock alt, all 1/0, and 2 wet cell batts dropping into the low 12's, upper 11's. Not recommended at all and he will probably smoke the amp eventually, but it's taken a fair beating so far.
Edited by Lbox88
it'll be fine OP. but how the hell will the amp/sub blow if you drop to 13.5v?
read more post less. mmmmkay.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
man i love your replys, but as stated above, you should be fine, the amp will never see .7 ohms after rise playing music.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
:orly3: What about when there is a pause in the bass line?
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
