Amart88 Posted February 13, 2012 Report Share Posted February 13, 2012 I have a Hifonics BRZ2100.1D mono amp it says its stable at 1 ohm. I will be wiring it at 1 ohm to a dual 2 ohm fi BTL 15 and I just noticed that the BTL is 1.4 ohms a coil which technically wires down to .7 ohms. Would this amp be able to handle running at .7 ohms in that situation or would ohm rise come into play anyway. I have a 270 amp alt and all 0 gauge with stock batt plus a kinetic hc1400. Thanks. /////////// Yes i know that the BTL can take more power and that I won't get the full 2100rms because of setting amp gains to a clean signal.\\\\\\\\\\\\\\\\\\ Quote My 2005 s10 blazer build. 4 zcon 18's walled. Link to comment Share on other sites More sharing options...
ehckz Posted February 13, 2012 Report Share Posted February 13, 2012 Im by no means an expert but from the things I have read you should be ok Quote Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60 Link to comment Share on other sites More sharing options...
guimond47 Posted February 13, 2012 Report Share Posted February 13, 2012 You can i have the brz 2400. but if u dont see over 13.5 volts ur gonna fry them like pancakes..LOL Quote Orion 2500D , 2-10" alpine type X. Custom enclosure,Alpine amp for mids and highs.Working on a center channel ATM Link to comment Share on other sites More sharing options...
Lbox88 Posted February 13, 2012 Report Share Posted February 13, 2012 (edited) I know a guy here with a BRZ2400 on a sp4 dual 2. 1.3 ohms per coil, 0.65 in parallel. He has a stock alt, all 1/0, and 2 wet cell batts dropping into the low 12's, upper 11's. Not recommended at all and he will probably smoke the amp eventually, but it's taken a fair beating so far. Edited February 13, 2012 by Lbox88 Quote UBL | Build Log Link to comment Share on other sites More sharing options...
Watch the bass Posted February 13, 2012 Report Share Posted February 13, 2012 I can´t do the math for that, but i think boxrise will do his work. Quote "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
Guest Posted February 13, 2012 Report Share Posted February 13, 2012 You can i have the brz 2400. but if u dont see over 13.5 volts ur gonna fry them like pancakes..LOL it'll be fine OP. but how the hell will the amp/sub blow if you drop to 13.5v? Quote Link to comment Share on other sites More sharing options...
Lbox88 Posted February 13, 2012 Report Share Posted February 13, 2012 I can´t do the math for that, but i think boxrise will do his work. Probably, but can't be 100% certain it will. Quote UBL | Build Log Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 13, 2012 Report Share Posted February 13, 2012 You can i have the brz 2400. but if u dont see over 13.5 volts ur gonna fry them like pancakes..LOL read more post less. mmmmkay. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Socky Posted February 13, 2012 Report Share Posted February 13, 2012 You can i have the brz 2400. but if u dont see over 13.5 volts ur gonna fry them like pancakes..LOL read more post less. mmmmkay. man i love your replys, but as stated above, you should be fine, the amp will never see .7 ohms after rise playing music. Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
Lbox88 Posted February 13, 2012 Report Share Posted February 13, 2012 You can i have the brz 2400. but if u dont see over 13.5 volts ur gonna fry them like pancakes..LOL read more post less. mmmmkay. man i love your replys, but as stated above, you should be fine, the amp will never see .7 ohms after rise playing music. What about when there is a pause in the bass line? Quote UBL | Build Log Link to comment Share on other sites More sharing options...
