since you are talkin about the "shops" I tell u my example..
so I ordered Singer alt for my 2000 accord and I went to the shop and asked how much would it cost to put the new alt in .. and I told him the pulley on the new alt is smaller than the stock one and I wasnt sure it i need to change a belt.. and he said:"so We just take the pulley from old one and put it on new one.." and i said that I dont wanna do that.. and he started to laugh real bad after I told him that smaller pulley makes the alt more effective on lower RPMs.. I didnt say anythin and just went out.. lol
+ he said that hes workin there for over 10 years...
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
It seems nobody here knows anything about sound quality. I see why home audiophiles laugh at the car audio scene.
It is physically impossible for any 18" sub to produce any frequency and especially transient frequencies, as precise as any sub with a cone smaller than 18". It's physics. There's no way around it.
And even more importantly, the difference in sound quality between any two different subs will be totally dependent on the signal it receives. IE: An 18" on a clean amp can sound better than a 10" on a dirty amp. Give them both a clean amp, and every time the 10" will sound cleaner, tighter, and more precise.
not entirely true. It's all in the design of the sub. It's a balence between motor force and the weight of the soft parts. You could easily have an 18 perform better than a 10 if the motor was designed fir the higher moving mass.
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
Okay, a properly designed enclosure would help. But it still doesn't change the fact that the 18" cone has a lot more mass and weight compared to smaller cones. It won't be able to "change" from say 80hz to 65hz anywhere near as quickly as a 10" would, simply because of the momentum of the heavier cone that the voice coil has to fight.
Oh, and I love the two sighs I got, from people who obviously blindly disagree with me while obviously not having the knowledge to back themselves up...
Lemme know when you stop talking theory. mmmkay
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
Isn't that why most people with larger subs use larger midbass woofers? Or at least a bunch of mid sized ones?
2 things
1. That is theory - a properly designed enclosure will allow it to hit higher frequencies just fine.
2. People will bigger subs do that because they are loud enough that they need to start investing in a really good front stage. The midbass drivers add to the akward 80-250hz range that is often times a dead spot in many systems. Not sure about you - but I don't want that sound coming from my subs. It would make it sound SO muddy regardless of the driver size (yes, tried it with an 8 inch sub with a fiberglass cone and a 10s, 12s and 15 inch sub with a normal cones. Same results)
ok i got a question? even if the 18" didnt change as quick would it be noticable to ear?
2 things
Depending on the type of music you listen to and the type of head unit, box, and amp, then yes, it can be very noticeable.
And yes, depending on the force of the voice coil, and pull of the magnet, an 18" could sound as good, as long as that force is equal to or greater than the extra air pressure resistance because of the extra cone area. But let's face it, when is an 18" actually scaled to the size of a lesser sized sub? Unless it is, it won't have the ability to produce the same type of sound on a larger scale. It's a totally different sub.
come on, how much heavier is an 18" paper cone than a 10" paper cone? or a 10" versus a 12" cone. you think a freaking 40+lb motor is going to have a hard time throwing those extra grams around?
2 things
you still don't get it. And the mass of the cone has almost no effect in sound quality. The suspension of almost any sub will matter far more than the small weight difference between a 10" cone to a 18" cone. Why might a sub sound muddy? It was designed wrong and the suspension is to stiff. Not because the cone is larger. It makes almost no difference.
front stage: tbd
